Speegs
#1 Posted : Saturday, July 2, 2016 8:27:03 PM(UTC)
Speegs
I was wondering if anyone has seen any thunderbolt 3 or USB C 3.1 capture devices yet?
Seems like a quad input/output thunderbolt 3 device would be useful. Well that's if NDI doesn't take over the world first :)
Speegs
desmar
#2 Posted : Saturday, July 2, 2016 11:32:04 PM(UTC)
desmar
Canada
Blacmagic Design UltraStudio 4K Extreme 3 is the only one that I know of...
Will probably see more come in the next few months at the European shows
CES 2017 most likely have lots by then as more and more PC / Laptops adopt
the new connector...
hablcc
#3 Posted : Sunday, September 17, 2017 8:54:47 AM(UTC)
hablcc
Has anyone seen a new capture device emerge at IBC?
curtismacd31
#4 Posted : Sunday, September 17, 2017 6:16:59 PM(UTC)
curtismacd31
AJA launched a new i/o 4k plus which is thunderbolt 3 and 12G-SDI
raugert
#5 Posted : Monday, September 18, 2017 12:10:45 PM(UTC)
raugert
Canada
I use a Sonnet Echo Express Thunderbolt II chassis with a Decklink Quad for (8) Inputs and a Decklink Duo2 for (4) Outputs. I connect it to vMix using an ASUS ROG laptop. Works very well and gives you lots of I/O.
If you need to have 4k, I've also used a Decklink 4k Pro card in the frame and it worked well with an HD input. I don't have a 4k device so I couldn't test it in 4k but I would imagine it would work...
Sonnet now makes a Thunderbolt III version of the chassis which should supports 3 cards. I would use that one in my next system.
Guest (5)
