Hardware Compatibility
PTZ Video Camera Datavideo PTC-150???
Joined: 9/13/2016(UTC) Posts: 112 Location: Ukraine Thanks: 6 times Was thanked: 5 time(s) in 4 post(s)
Hello! I want to buy these cameras http://www.datavideo.com/product/PTC-150for the studio, but did not find anywhere - are they compatible with vMix ?? Who can tell how much they are compatible with vMix and if additional options are required for their connection, what ???
Murchik wrote:Hello! I want to buy these cameras http://www.datavideo.com/product/PTC-150for the studio, but did not find anywhere - are they compatible with vMix ?? Who can tell how much they are compatible with vMix and if additional options are required for their connection, what ??? at least someone can tell about the topic of these cameras ??
You have been a member since:: 8/20/2014(UTC) Posts: 388
Thanks: 29 times Was thanked: 78 time(s) in 50 post(s)
It outputs sdi and HDMI -- so those will work in vmix. Control and RTSP is another matter.
kjones9999 wrote:It outputs sdi and HDMI -- so those will work in vmix. Control and RTSP is another matter. I understand perfectly that by SDI I can get an image. I'm interested in compatibility management, so you do not need additional controllers, consoles, etc. I do not want to take Optix cameras - they are very unreliable with glitches ... everyone who has already worked with them ... refuses ...
Joined: 10/13/2012(UTC) Posts: 1,161 Location: Melbourne Thanks: 220 times Was thanked: 199 time(s) in 181 post(s)
THese are the supported cameras.
Panasonic CGI PTZ AW-HE40, 50, 60, 65, 70, 120 and 130 series AW-UE70 4K series All Panasonic PTZ cameras that list support for CGI control over Ethernet in the specifications
PTZ Optics VISCA UDP PTZ Optics 12x and 20x models Other cameras supporting VISCA over UDP such as ValueHD
Sony CGI PTZ SRG-300 series SRG-360 series
Sony VISCA over IP SRG-300 series (with firmware upgrade) SRG-360 series Lumens VC-A50P Other cameras supporting VISCA over IP
iSmart VISCA UDP AMC series IP PTZ Cameras
However, the camera you linked to has support for Visca over IP, so you may find it works. The best thing to do is to get Datavideo to supply a unit to vMix to test and include as a supported product.
ask wrote:THese are the supported cameras.
However, the camera you linked to has support for Visca over IP, so you may find it works. The best thing to do is to get Datavideo to supply a unit to vMix to test and include as a supported product. ordered the dealer testing DATAVIDEO 150 for compatibility with VMIX, at the very least they are ready to provide one camera for self-testing ... I'm waiting for the results or the camera ... if I really get excited and write in the topic.
People, help if you can! I already got this camera for testing! Which turned out to be even better than Sony CGI PCCDG -300 series. But the open control protocol is "In VISCA, the side outputting commands, for example, the computer is called the controller, while the side receiving the commands, such as a PTC-150, is called the the peripheral device. a peripheral device in VISCA .In VISCA, up to seven peripheral devices like the BRC300 / P can be connected to the controller using RS-232C / RS422 standard. . " Management for IP is only available with own software that is separate (ie requires a separate camera operator or the presence of a remote control), which is not suitable at all! There is an open documentation for the command set of both the IP and the RS-422, but I do not do much in this ... who can help by the compatibility of this type of cameras with me? Well, these cameras are very popular for both the quality of the burn and the price, but compatibility is needed with VMIX ... Help me - I was given this camera for 5 days ... this morning, and I'm already thrilled! http://www.datavideo.com/product/PTC-150Wby reference there is everything! A set of commands for DVIP & rs-422, I do not care by what standard to work - but I really need these cameras! since Sony CGI PTZ SRG-300 series cost me 4500 USD in the country, and this camera is even better than 2850 USD. Help ... please ... well, really really need! Murchik attached the following image(s): 20170929_153540.jpg (915kb) downloaded 2 time(s). 20170929_153549.jpg (877kb) downloaded 1 time(s).You cannot view/download attachments. Try to login or register.
I can even connect to it via DVIP (although it is written on the manufacturer's website that it is not available) just need to understand the set of commands ... nothing is working. Murchik attached the following image(s): 20170930_013542.jpg (1,832kb) downloaded 6 time(s). 20170930_013506.jpg (1,002kb) downloaded 5 time(s).You cannot view/download attachments. Try to login or register.
