Murchik
#1 Posted : Monday, August 28, 2017 7:07:46 AM(UTC)
Murchik
Ukraine
Hello! I want to buy these cameras http://www.datavideo.com/product/PTC-150
for the studio, but did not find anywhere - are they compatible with vMix ??
Who can tell how much they are compatible with vMix and if additional options are required for their connection, what ???
Murchik
#2 Posted : Wednesday, September 6, 2017 3:57:15 PM(UTC)
Murchik
Ukraine
at least someone can tell about the topic of these cameras ??
kjones9999
#3 Posted : Sunday, September 10, 2017 10:48:42 PM(UTC)
kjones9999
It outputs sdi and HDMI -- so those will work in vmix. Control and RTSP is another matter.
Murchik
#4 Posted : Monday, September 11, 2017 1:53:35 AM(UTC)
Murchik
Ukraine
I understand perfectly that by SDI I can get an image.
I'm interested in compatibility management, so you do not need additional controllers, consoles, etc.
I do not want to take Optix cameras - they are very unreliable with glitches ... everyone who has already worked with them ... refuses ...
ask
#5 Posted : Monday, September 11, 2017 7:13:59 PM(UTC)
ask
THese are the supported cameras.
Panasonic CGI PTZ
AW-HE40, 50, 60, 65, 70, 120 and 130 series
AW-UE70 4K series
All Panasonic PTZ cameras that list support for CGI control over Ethernet in the specifications
PTZ Optics VISCA UDP
PTZ Optics 12x and 20x models
Other cameras supporting VISCA over UDP such as ValueHD
Sony CGI PTZ
SRG-300 series
SRG-360 series
Sony VISCA over IP
SRG-300 series (with firmware upgrade)
SRG-360 series
Lumens VC-A50P
Other cameras supporting VISCA over IP
iSmart VISCA UDP
AMC series IP PTZ Cameras
However, the camera you linked to has support for Visca over IP, so you may find it works. The best thing to do is to get Datavideo to supply a unit to vMix to test and include as a supported product.
Murchik
#6 Posted : Sunday, September 17, 2017 1:56:01 PM(UTC)
Murchik
Ukraine
Panasonic CGI PTZ
AW-UE70 4K series
Sony CGI PTZ
SRG-300 series
SRG-360 series
Sony VISCA over IP
SRG-360 series
Lumens VC-A50P
iSmart VISCA UDP
ordered the dealer testing DATAVIDEO 150 for compatibility with VMIX, at the very least they are ready to provide one camera for self-testing ... I'm waiting for the results or the camera ... if I really get excited and write in the topic.
Murchik
#7 Posted : Saturday, September 30, 2017 6:07:30 PM(UTC)
Murchik
Ukraine
People, help if you can! I already got this camera for testing! Which turned out to be even better than Sony CGI PCCDG -300 series. But the open control protocol is
"In VISCA, the side outputting commands, for example, the computer is called the controller, while the side receiving the commands, such as a PTC-150, is called the the peripheral device. a peripheral device in VISCA .In VISCA, up to seven peripheral devices like the BRC300 / P can be connected to the controller using RS-232C / RS422 standard. . "
Management for IP is only available with own software that is separate (ie requires a separate camera operator or the presence of a remote control), which is not suitable at all!
There is an open documentation for the command set of both the IP and the RS-422, but I do not do much in this ... who can help by the compatibility of this type of cameras with me? Well, these cameras are very popular for both the quality of the burn and the price, but compatibility is needed with VMIX ...
Help me - I was given this camera for 5 days ... this morning, and I'm already thrilled!
http://www.datavideo.com/product/PTC-150W
by reference there is everything! A set of commands for DVIP & rs-422, I do not care by what standard to work - but I really need these cameras! since Sony CGI PTZ
SRG-300 series cost me 4500 USD in the country, and this camera is even better than 2850 USD.
Help ... please ... well, really really need!
Murchik attached the following image(s):
Murchik
#8 Posted : Saturday, September 30, 2017 6:41:12 PM(UTC)
Murchik
Ukraine
I can even connect to it via DVIP (although it is written on the manufacturer's website that it is not available) just need to understand the set of commands ... nothing is working.
