3rd Party Software and Development
vTask A 24/7 Automation and Scheduling for vMix
Thanks: 1 times Was thanked: 39 time(s) in 12 post(s)
Dear, vTask User / Customer, My name is Eric Asiedu the founder of VFXBLEND LTD. and creator of THEN vMixTask and NOW vTask. A Brief History This software was initially hosted on the official vMilx Forum, when officials of vMix asked us to change the name because vMix is their trademark and that resulted in the name vTask. Along the line, we worked with AnnanStudios and its been fun and we are now moving to the next phase. As of (24rd Febuary, 2018) vTask 24/7 Automation and Scheduling software is being rooted back to VFXBLEND LTD. These changes would not affect your product. What Now? because we care about you, we've made sure the following are in place: 1. All License holder are still valid only if they download the latest update that comes with this announcement. 2. All Support and resources should be redirected to the official VFXBLEND website www.vfxblend.com , the website has a forum to keep our community up and running. This announcement comes with a discount. Purchase VTask 2.1.20 for only $49.99 Please see the videos on our website about one big change in the latest update vTask 2.1.20 and also to get you started on this new website. Regards Eric Asiedu CEO VFXBLEND LTD. -- We code, create and blend Multimedia From Media Advertising, Film & TV Production To Music Production VFX BLEND: your imagination is our creation.
 18 users thanked AnnanStudios for this useful post.
vijay6672 on 8/25/2017(UTC), desmar on 8/25/2017(UTC), ask on 8/26/2017(UTC), Damn2Good4U on 8/26/2017(UTC), coolnetgr on 8/26/2017(UTC), jakefilmpro on 8/26/2017(UTC), ON.tv Channels on 8/26/2017(UTC), ceejay7777 on 8/28/2017(UTC), RobLambert on 8/28/2017(UTC), avsoundguy on 8/31/2017(UTC), Toongielen on 9/1/2017(UTC), sinc747 on 9/2/2017(UTC), liwarnyamannya on 9/2/2017(UTC), corporatejames on 9/3/2017(UTC), RichShumaker on 9/4/2017(UTC), NeObr on 9/30/2017(UTC), genegreenwood on 10/17/2017(UTC), joel72004 on 2/19/2018(UTC)
Thanks: 106 times Was thanked: 2 time(s) in 2 post(s)
Fantastic news - we've been waiting for such a product... and it's free to boot! Many thanks for all your hard work - looking forward to trying it out on 1st September John
 1 user thanked ON.tv Channels for this useful post.
 1 user thanked AnnanStudios for this useful post.
Joined: 9/1/2015(UTC) Posts: 128  Location: Ecuador Thanks: 2 times Was thanked: 16 time(s) in 12 post(s)
They are excellent news, this is what was missing to complete in vmix ... Many will be happy. Thank you for creating this tool. We're waiting
Joined: 2/2/2017(UTC) Posts: 8 Location: Balen, Belgium
This will be my solution for visual radio ! Thx a lott !!
Joined: 8/21/2015(UTC) Posts: 324   Location: Cornwall, Ontario, Canada Thanks: 18 times Was thanked: 80 time(s) in 60 post(s)
Installed on 4 different machines and did not work. All 4 machines running Windows 10 Pro Version 10.0.15063 Build 15063 All getting same error Added Event Logs in Attachement File Attachment(s):  Event Logs.zip (4kb) downloaded 7 time(s).desmar attached the following image(s):  Capture.PNG (48kb) downloaded 24 time(s).You cannot view/download attachments. Try to login or register.
yes same error, not opening [img][/img] island tv attached the following image(s):  Untitled.png (1,089kb) downloaded 41 time(s).You cannot view/download attachments. Try to login or register.
you need to install vlc 32bit
 2 users thanked AnnanStudios for this useful post.
Thanks: 211 times Was thanked: 13 time(s) in 12 post(s)
Had same error, loaded vlc-2.2.6-win32.exe and it started right up, now to figure out how to use it properly, pretty cool so far
 2 users thanked avsoundguy for this useful post.
Joined: 9/2/2017(UTC) Posts: 4 Location: Solano County
Thanks. Now to figure out how the video progress bar works on win10, cause you can drag the slider around, and it seems to bork up the app, and doesn't recognize the highlighted scene, especially when a event is deleted. I'm running this on Windows 10 Professional, by the way.
can you add aspected ratio to video files :)
app works well
There are collection of tutorials for vTask 2.0 you will be notified in few hours
 5 users thanked AnnanStudios for this useful post.
Joined: 6/29/2011(UTC) Posts: 313   Location: Florida Thanks: 6 times Was thanked: 33 time(s) in 32 post(s)
Thank yo so much, A definite step in the right direction. Trimming clips is a bit difficult when they're long clips. Need to be able to make fine adjustments to in and out points. Also I noticed when a assets is finished it remains in vMix library and is not closed so they tend to really fill up the screen. It would be great if the Add Command properties panel could have the commands categorized similar to vMix Select function panel so we don't have to search the entire list. I wasn't able to set trim in and out point manually in the properties panel for video assets. It would be nice if the video would not start playing when added to list or have a option not to. I don't know how far you plan on taking vTask but I can see a real future if you do. Thank you for your hard work
Egriswold wrote:Thank yo so much, A definite step in the right direction. Trimming clips is a bit difficult when they're long clips. Need to be able to make fine adjustments to in and out points. Also I noticed when a assets is finished it remains in vMix library and is not closed so they tend to really fill up the screen. It would be great if the Add Command properties panel could have the commands categorized similar to vMix Select function panel so we don't have to search the entire list. I wasn't able to set trim in and out point manually in the properties panel for video assets. It would be nice if the video would not start playing when added to list or have a option not to. I don't know how far you plan on taking vTask but I can see a real future if you do. Thank you for your hard work Thank you, your report has been considered we will do our best to reflect in the next update which is pretty soon Regards AnnanStudios.
Forum Rank:: Advanced Member
Joined: 4/4/2016(UTC) Posts: 236  Location: Not Los Angeles CA Thanks: 86 times Was thanked: 28 time(s) in 23 post(s)
THANKS. I have been using vTask for just about 5 hours and it is awesome. This is EXACTLY what I was looking for to do a new and improved 'Moviefest'. A friend years ago had a Moviefest, Hey Phil if you ever read this, he had wired the house with Coax and would play to all the TV's on Channel 3 the movies in the Festival. Hence Moviefest and each had a theme, I wrote about them in my blog post, http://www.richshumaker....film-fest-dbmc-festival/I will be setting up my new and improved MovieFest soon and I will create something to let everyone know about it. Tomorrow I will be testing some more and do a 'live' stream. I did 18 Document Don't Create Live Daily Wrap Up Shows using vMix and now I am going to play them back to back and add some 'extras'. This takes 18 individual 3 to 5 minutes shows and makes a 2 hour compilation. I will be adding bonus videos I have not shown anyone yet. During the show it would be cool to do Overlays with Titles to THANK people in real time that might be donating or chatting during the 'live' event. Also I am trying to figure out how I could 'Pop Up' in an overlay during the show and say HI and Thank everyone that is checking it out. Thank you very much for making this and as always THANKS vMix for the AWESOME SOFTWARE. Rich Shumaker
RichShumaker wrote:THANKS. I have been using vTask for just about 5 hours and it is awesome. This is EXACTLY what I was looking for to do a new and improved 'Moviefest'. A friend years ago had a Moviefest, Hey Phil if you ever read this, he had wired the house with Coax and would play to all the TV's on Channel 3 the movies in the Festival. Hence Moviefest and each had a theme, I wrote about them in my blog post, http://www.richshumaker....film-fest-dbmc-festival/I will be setting up my new and improved MovieFest soon and I will create something to let everyone know about it. Tomorrow I will be testing some more and do a 'live' stream. I did 18 Document Don't Create Live Daily Wrap Up Shows using vMix and now I am going to play them back to back and add some 'extras'. This takes 18 individual 3 to 5 minutes shows and makes a 2 hour compilation. I will be adding bonus videos I have not shown anyone yet. During the show it would be cool to do Overlays with Titles to THANK people in real time that might be donating or chatting during the 'live' event. Also I am trying to figure out how I could 'Pop Up' in an overlay during the show and say HI and Thank everyone that is checking it out. Thank you very much for making this and as always THANKS vMix for the AWESOME SOFTWARE. Rich Shumaker for overlays Check out tutorials on our youtube in few hours to come
Hi
Although I haven't tried vTask yet but only watched the tutorial videos and followed first users experiments reporting on facebook, I would like to suggest one thing that is very important to my eyes.
So far, vTask doesn't seem to support network operation, that is to say being able to run on a remote computer using media files located anywhere on the network.
- There is a setting parameter for vMix host IP address, but users report it is complaining of losing connection unless it runs on the same PC as vMix. - The media files show a local path on the host vTask is used. This path is not correct as of vMix host. - I suggested a user to create shared folders that would be the same on both PCs, but it doesn't seem to work anyway. - It doesn't seem to support UNC paths at all which vMix does
I believe such a playout solution should be able to run with a multitier (or at least a 3 tier) architecture. For example: - vMix is PC1 - vTask is PC2 - Media files are stored on a server or a NAS or a SAN or even multiple ones.
This would make vTask a professional solution for playout.
Best regards Guillaume
 2 users thanked DWAM for this useful post.
