neo5287
#1 Posted : Tuesday, May 7, 2013 8:11:00 PM(UTC)
neo5287
Can anyone help me with understanding how to use AddInput Function, both in shortcut and API usage.
I would like to understand how to add RTMP streams via API.
Also is there is a way to reset the inputs automatically, either via api or a config setting, when an input looses connection to rtmp stream it does not automatically connect again, in the UI i can right click on the input and select reset, but theres no easy way to automate it or set it to auto retry.
Good bit of software!
Niall
#2 Posted : Thursday, May 9, 2013 1:40:29 AM(UTC)
The AddInput function in the API only supports the following formats:
Video
Photos
Xaml
To load a video, an example request would be:
http://localhost:8088/API/?Function=AddInput&Value=Video|C:\video.wmv
To add an image the request would be:
http://localhost:8088/API/?Function=AddInput&Value=Image|C:\image.jpg
I will add this information to the help file.
neo5287 on 5/9/2013(UTC)
neo5287
#3 Posted : Thursday, May 9, 2013 5:33:28 AM(UTC)
neo5287
Hi Martin,
Thanks for the quick response. Could I possibly get RTMP streams via API added to the feature request list? Should I raise a thread in the other board?
Would you be able to give any input on the second half of my problem. Resetting the RTMP streams. Currently if a RTMP stream loses connection to vMix the input freezes. I quite like the fact it doesnt just go black but when the connection comes back it requires a manual reset on the input to get it to work again.
I was hoping there was a way to reset them via the API if there was no way to make it automatic, would this be something you would consider for a later release?
Best regards
Niall
