The feature in the replay module to remember Replay shot "tags" is great but is is always cleared when you create a new replay input or delete the existing replay files through the setup interface. In most sports there are usually set tags that are needed to be used during the game, similar to a statistician program e.g. in basketball "3 point made" "3 point missed" "steal" "Turnover - poor pass" etc. What I would like to see is the ability to import a list of tags, and/or other data, into the replay input when you have set it up. Additionally, if only using one camera for a replay, you only have one column of metadata. It would also be nice to be able to have the ability to create additional columns that could then be used for team/player names and numbers. This would then facilitate the quicker selection of the data when creating clips and highlight reels.
Joined: 8/2/2013(UTC) Posts: 1,113   Location: Fairhope, Alabama USA Thanks: 607 times Was thanked: 207 time(s) in 173 post(s)
Joined: 7/31/2016(UTC) Posts: 2 Location: Albuquerque, New Mexico
Thanks: 12 times Was thanked: 33 time(s) in 28 post(s)
The most of your feature request is already there:
- add instant replay input - open settings of instant replay input - select "Tags" in "Configure Instant Replay" dialog
There you will find Import/Export functions for tag management.
Regards Patrick
 1 user thanked pm for this useful post.
Had not seen this. And yes it does the import from a txt file. However it populates all colums with the same data. What I am looking for is an import that brings separate lists into the columns. So you can read across the screen and see something like: 3 point made; Home team; Player #12
