XAML standing list with external data
Joined: 12/27/2012(UTC) Posts: 5,521  Location: Belgium Thanks: 318 times Was thanked: 1021 time(s) in 838 post(s)
Hi All
I am trying to create some sort of standing / result listing overlay updated by puling external data
I have managed to create this using xml files but have not been able to find a way to update this list after a change of the data on screen.
Is anyone more familiar with xaml in order to retrieve external data (from other source) ?
Can also anyone explain the presence of a XAML.VB file and how to use it. A practical example would help me a lot.
There have been a few similar topics here already but they haven't helped me much so far.
Pushing data through http requests I managed but that only good when you are in control of this data yourself.
Appreciate any feedback
Guy
Thanks: 5 times Was thanked: 2 time(s) in 2 post(s)
what you can do is open a new thread on the code side, i'm doing this in C#, but you need to load the DLL in Vmix, I am working on making a library for this, but this wont be made public for some time Here a link that might help you in VB http://support.microsoft.com/kb/315577
Thank you for responding MrFreeze.
To be honest I am more lost now .
Wish there was a little more documentation in regards to the XAML possibilities. Being able to efficiently change title information during a sporting event , especially where this info has to be avaliable quickly and flexible seems to be a possibility with vMix. Browsing through numerous xaml examples I keep running into situations where those do not work in vMix unles i change some ordering in the code . I assumed for example the xaml.vb files had to do with codebehind but I cant seem to find the actual truthfulness to it .
I would think titling and information retrieving (players info) , resultsdisplay quickly would be one of the options benefitial to live event production .
Casparcg has a good system in that sense with flashtemplates and relative easy to create clients , based on that I only see me able to create similar clients using htprequests for sending the info to xaml templates.
reason: displaying sportsman details, switch to scoring the performance , displaying an intermediary standing order over footage after all within 1 minute of a performance repeatedly up to a few hundred times .
I've made a quick example for you in C# example folderplease note that there is an infinite loop in this code. As a result you will need to close vmix through task manager. Michael
