Vmix to Wowza private local instance
How exactly can I connect Vmix to a locally running Wowza streaming engine instance?
I found some tutorials piping Vmix to VLC and using VLC to stream to Wowza, but this sound quite complicated, given that e.g. Wirecaster allows direct streaming to a local Wowza engine instance. I see Wowza Cloud in Vmix, but Wowza private instance is a locally running Wowza engine on the same machine (e.g. if I stream from VLC I would stream UDP-legacy to 127.0.0.1)
So is there a way to directly stream form Vmix to locally running Wowza engine instance, and if so, what would be the setup? I could not find instructions anywhere and I searched the forums for Wowza.
Thank you.
Joined: 6/23/2016(UTC) Posts: 106 Location: Milwaukee
Thanks: 1 times Was thanked: 11 time(s) in 10 post(s)
Not sure if it is the same thing but I have a WOWZA instance out on Amazon AWS that I stream to from VMix. And from there I distribute to multiple providers at once. Is this what you are looking at doing? I set it up 2 years ago, and I don't recall exactly how I did it, but if this is what you are looking to do, I may be able to help.
you should be able to do an rtmp feed.
Try rtmp://127.0.0.1/live
then insert key name.
jvphobic wrote:Not sure if it is the same thing but I have a WOWZA instance out on Amazon AWS that I stream to from VMix. And from there I distribute to multiple providers at once. Is this what you are looking at doing? I set it up 2 years ago, and I don't recall exactly how I did it, but if this is what you are looking to do, I may be able to help. Yes exactly that, but instead of running wowza on AWS, it will be run locally (localhost).
Thanks: 3 times Was thanked: 13 time(s) in 12 post(s)
You need to set up a custom RTMP
If you didnt mess with the default option it should be rtmp://127.0.0.1/live
Use anything as a key, and the auth options depends on your configurations as well. Locally I usually remove input security in wowza so I don't have to input user/PW in vmix.
Good luck.
 1 user thanked RandomStreamer for this useful post.
RandomStreamer nailed it.
 1 user thanked jvphobic for this useful post.
