BitDefender does not allow to install vMix - It Shows Virus
Hi, BitDefenter shows vMix exe infected with a virus Named "vMix Gen:VAriant.MSILPerseus.119161", It Blocked the installation.. How to resolve this? Janaka attached the following image(s):  Virus.png (52kb) downloaded 0 time(s).You cannot view/download attachments. Try to login or register.
Joined: 1/13/2010(UTC) Posts: 5,345  Location: Gold Coast, Australia Was thanked: 4749 time(s) in 1632 post(s)
This is a false positive. You can either check BitDefender for updates that might resolve this or may need to uninstall BitDefender and go back to Windows Defender until they resolve the problem.
Martin vMix
I had the same error showing today.
To fix you will need to repair BitDefender. This can be found under the Windows Start menu -> BitDefender 2017 -> Repair or Uninstall
Once you've completed the repair, restart your computer and you should be able to use vMix again.
Hope that helps Brian
I had this happen also with Bitdefender. What I did was add vmix.exe and vmix64.exe to the ignore list in Bitdefender.
Thanks All for the Replies... Will Try suggested
