Janaka
#1 Posted : Tuesday, August 22, 2017 12:15:09 AM(UTC)
Janaka
BitDefenter shows vMix exe infected with a virus Named "vMix Gen:VAriant.MSILPerseus.119161", It Blocked the installation.. How to resolve this?
Janaka attached the following image(s):
#2 Posted : Tuesday, August 22, 2017 12:42:25 AM(UTC)
Was thanked: 4670 time(s) in 1608 post(s)
This is a false positive. You can either check BitDefender for updates that might resolve this
or may need to uninstall BitDefender and go back to Windows Defender until they resolve the problem.
marketinghits
#3 Posted : Tuesday, August 22, 2017 3:48:22 PM(UTC)
marketinghits
I had the same error showing today.
To fix you will need to repair BitDefender. This can be found under the Windows Start menu -> BitDefender 2017 -> Repair or Uninstall
Once you've completed the repair, restart your computer and you should be able to use vMix again.
Hope that helps
Brian
jpeg2RAW
#4 Posted : Tuesday, August 22, 2017 9:11:36 PM(UTC)
jpeg2RAW
I had this happen also with Bitdefender. What I did was add vmix.exe and vmix64.exe to the ignore list in Bitdefender.
Janaka
#5 Posted : Wednesday, August 23, 2017 4:43:05 AM(UTC)
Janaka
Thanks All for the Replies... Will Try suggested
