94StrickeR
#1 Posted : Sunday, August 20, 2017 12:18:10 PM(UTC)
94StrickeR
Hi!
I'd like to ask You: would be it possible to create an ask "close input" after clicking "close" on input rectangle?
It would be great, because sometimes we accidently close an input, trying to show it as overlay.
Best regards!
#2 Posted : Sunday, August 20, 2017 12:26:26 PM(UTC)
Use a shortcut key to display one of your overlays ;-)
richardgatarski
#3 Posted : Sunday, August 20, 2017 3:38:06 PM(UTC)
richardgatarski
This is an old request that seems to be quite popular. Maybe sometime it will be implemented ;)
#4 Posted : Sunday, August 20, 2017 3:49:38 PM(UTC)
@ 94StrickeR & richardgatarski
You are quite right Richard, but if you remember correctly, I believe the solution implemented instead was the "undo" function in the top menu (counter clockwise circular arrow), which in my estimation is brilliant. If you made the mistake of accidentally closing the Input, one click later and you are back in business. If you did not make a mistake, there is no nuisance of a confirmation click. Simply Brilliant.
Just my thoughts.
sinc747 on 8/21/2017(UTC)
