Feature Requests
"Close input?" ask, after clicking "close" input.
Hi!
I'd like to ask You: would be it possible to create an ask "close input" after clicking "close" on input rectangle? It would be great, because sometimes we accidently close an input, trying to show it as overlay.
Best regards!
Joined: 12/27/2012(UTC) Posts: 5,536  Location: Belgium Thanks: 319 times Was thanked: 1022 time(s) in 839 post(s)
Use a shortcut key to display one of your overlays ;-)
This is an old request that seems to be quite popular. Maybe sometime it will be implemented ;)
@ 94StrickeR & richardgatarski
You are quite right Richard, but if you remember correctly, I believe the solution implemented instead was the "undo" function in the top menu (counter clockwise circular arrow), which in my estimation is brilliant. If you made the mistake of accidentally closing the Input, one click later and you are back in business. If you did not make a mistake, there is no nuisance of a confirmation click. Simply Brilliant. Just my thoughts.
Feature Requests
