puruzio
#1 Posted : Sunday, August 20, 2017 3:21:24 PM(UTC)
puruzio
In trying to use the Blackmagic ATEM switch for the camera input into Vmix, I get the above error message. See more detail in the screenshot image link below.
We currently record videos using Blackmagic Media Express with the ATEM switch and H264 Pro Recorder connected to this Windows 7 PC that I'm running vMix now, so I have to believe the issue is within vMix.
[img]http://imgur.com/QNc2WBK[/img]
Can you please advise what I can try to get this to work? Thanks.
puruzio attached the following image(s):
Capturevmix error.PNG (48kb) downloaded 38 time(s).
Zetor1980
#2 Posted : Sunday, August 20, 2017 5:22:06 PM(UTC)
Zetor1980
Atem 1 accepts and sends only interlaced signals.
puruzio
#3 Posted : Sunday, August 20, 2017 7:44:15 PM(UTC)
puruzio
As I said above, ATEM switcher is connected to this PC via H264 Recorder. However, for some reason, H264 won't show up in the list of input devices along with ATEM switcher? The only other thing in the list is called "sample input" Any idea why? Someone had told me H264 would work with VMix.
Zetor1980
#4 Posted : Sunday, August 20, 2017 8:33:01 PM(UTC)
Zetor1980
H.264 couldn't be camera input signal to vMix.
kjones9999
#5 Posted : Sunday, August 20, 2017 9:49:33 PM(UTC)
kjones9999
Try 59.94i
thanks 1 user thanked kjones9999 for this useful post.
puruzio on 8/21/2017(UTC)
puruzio
#6 Posted : Monday, August 21, 2017 9:15:40 PM(UTC)
puruzio
59.94i did the trick. I can record the video from the switcher now.
It doesn't seem to record the audio, though. Can you see how it might happen?
I didn't disable any audio options under the Record setting in vMix.
Guest (5)
