ratcast
#1 Posted : Friday, March 8, 2013 1:13:34 PM(UTC)
ratcast
Has anyone heard if the HDMI input on some Alienware laptops is recognized in Vmix?
Would love to use an HDMI cable from the camera right into the program without a capture card, if it's possible.
dave
#2 Posted : Thursday, May 2, 2013 6:22:26 PM(UTC)
Seems its detected but says not working :-(
other capture software also recognizes it and does work
#3 Posted : Thursday, May 2, 2013 9:41:09 PM(UTC)
What error message do you see?
#4 Posted : Friday, May 3, 2013 4:34:48 AM(UTC)
Device connected to system does not work. (translated)
Although I installed in English the errors are in my Windows language
Regards
#5 Posted : Saturday, May 4, 2013 2:18:13 AM(UTC)
Any other way of helping with the error ?
as the mention above is the only thing I get
#6 Posted : Saturday, May 4, 2013 2:32:09 AM(UTC)
Have you tried different some different resolution and frame rate (system) options in the capture window?
That error message usually means the device is not working (at all), but as you have said it works in other programs
I can only guess it is saying that because the selected resolution does not match the camera.
#7 Posted : Saturday, May 4, 2013 2:57:25 AM(UTC)
Playing with resolutions etc:
Capture resolution not supported by this device
following are suported
720x576 PAL 50p YUY2
720x480 NTSC 59.94p YUY2
640x480 NTSC 59.94p YUY2
1920x1080 PAL 50i or 25p YUY2
#8 Posted : Saturday, May 4, 2013 7:38:47 AM(UTC)
The way I am testing it is not by means of a camera but a direct connection of the HDMI out to in. This gives me basically a second screen (without monitor).
Vlc, even FMLE can grab it directly (see it as a directshow source)
#9 Posted : Wednesday, July 31, 2013 4:09:42 AM(UTC)
Could anyone confirm if this 'little' issue has been resolved in the latest version ?
I finally have a HDMI cam , and am able to get the video through build in HDMI-IN to several video software recorders (but not all) .
Sorry can not test myself as I am way past demo time
Guest (10)
