API - Send multiple Values/ Inputs at once
Is there a way for the API to send multiple Inputs or Values at once?
Especially the following are interesting to me:
Shut on/off multiple MultiViewOverlays at once, currently it's like /api/?Function=MultiViewOverlayOn&Input=4&Value=1 /api/?Function=MultiViewOverlayOn&Input=4&Value=3 /api/?Function=MultiViewOverlayOn&Input=4&Value=5
is there a way to combine it somehow like this (results as invalid parameters) /api/?Function=MultiViewOverlayOn&Input=4&Value=1,3,5
Is there a way to set the Textfields of different Inputs at once API/?Function=SetText&Input=1&SelectedName=MyText&Value=test API/?Function=SetText&Input=2&SelectedName=MyText&Value=test API/?Function=SetText&Input=3&SelectedName=MyText&Value=test
becomes something like? API/?Function=SetText&Input=1&Input=2&Input=3&SelectedName=MyText&Value=test or API/?Function=SetText&Input=1,2,3&SelectedName=MyText&Value=test
Thanks in advance
Yes there is. Take a look at http://www.vmix.com/know...-using-scripting-and-api for more info. Basically you make one (post) request where the data includes Function=ScriptStartDynamic, and the Value is your commands - one on each line, actually pretty equal to the ones you provided.
Thanks for your replay, but i guess scripting is only availible to the 4K/pro and not the HD version of vmix...
slxxi wrote:Thanks for your replay, but i guess scripting is only availible to the 4K/pro and not the HD version of vmix... Hi slxxi. You are not limited to send the requests to the Web API via scripting, you can send the request from any application or browser.
Joined: 11/14/2012(UTC) Posts: 402  Location: Finland Thanks: 256 times Was thanked: 39 time(s) in 37 post(s)
slxxi wrote:i guess scripting is only availible to the 4K/pro and not the HD version of vmix... In my opinion scripting should be available for HD customers also. I hope Martin will enable it in v20. Kind regards, Jan
I think the price for the 4K and Pro version are so low, and the features are so great and powerful, so you should support vMix by buying the more expensive versions (which is not expensive after all!).
