slxxi
#1 Posted : Thursday, August 17, 2017 1:35:24 PM(UTC)
slxxi
Is there a way for the API to send multiple Inputs or Values at once?
Especially the following are interesting to me:
Shut on/off multiple MultiViewOverlays at once, currently it's like
/api/?Function=MultiViewOverlayOn&Input=4&Value=1
/api/?Function=MultiViewOverlayOn&Input=4&Value=3
/api/?Function=MultiViewOverlayOn&Input=4&Value=5
is there a way to combine it somehow like this (results as invalid parameters)
/api/?Function=MultiViewOverlayOn&Input=4&Value=1,3,5
Is there a way to set the Textfields of different Inputs at once
API/?Function=SetText&Input=1&SelectedName=MyText&Value=test
API/?Function=SetText&Input=2&SelectedName=MyText&Value=test
API/?Function=SetText&Input=3&SelectedName=MyText&Value=test
becomes something like?
API/?Function=SetText&Input=1&Input=2&Input=3&SelectedName=MyText&Value=test
or
API/?Function=SetText&Input=1,2,3&SelectedName=MyText&Value=test
Thanks in advance
stigaard
#2 Posted : Thursday, August 17, 2017 5:18:51 PM(UTC)
stigaard
Denmark
Yes there is.
Take a look at http://www.vmix.com/know...-using-scripting-and-api for more info.
Basically you make one (post) request where the data includes Function=ScriptStartDynamic, and the Value is your commands - one on each line, actually pretty equal to the ones you provided.
slxxi
#3 Posted : Thursday, August 17, 2017 5:54:39 PM(UTC)
slxxi
Thanks for your replay, but i guess scripting is only availible to the 4K/pro and not the HD version of vmix...
stigaard
#4 Posted : Friday, August 18, 2017 3:17:34 AM(UTC)
stigaard
Denmark
Hi slxxi.
You are not limited to send the requests to the Web API via scripting, you can send the request from any application or browser.
jet
#5 Posted : Friday, August 18, 2017 10:59:23 AM(UTC)
jet
Was thanked: 40 time(s) in 38 post(s)
In my opinion scripting should be available for HD customers also.
I hope Martin will enable it in v20.
Kind regards,
Jan
stigaard
#6 Posted : Friday, August 18, 2017 4:27:15 PM(UTC)
stigaard
Denmark
I think the price for the 4K and Pro version are so low, and the features are so great and powerful, so you should support vMix by buying the more expensive versions (which is not expensive after all!).
