BigApple
#1 Posted : Saturday, August 12, 2017 9:07:13 PM(UTC)
BigApple
Hello vmix Friends.
I have these strange horizontal "tearing" lines in my 4K input on my Aja IO 4K (Or whatever it is called) only when I use the 4K input .. on the 1080 SDI inputs is all well.
I DO NOT get them when I use the AJA capturing software. Only on Vmix see the video below the line seems a little delayed .. and the lines will not stay there sometimes I get 2 of them. And sometimes I do not have them at all... But because of it I can not use 4k on vmix. (See video for sample)
this happens on several versions I have tried...even on the latest 19.0.0.54
File Attachment(s):
capture - 11 August 2017 - 09-23-48 PM.wmv (224kb) downloaded 9 time(s).
BigApple attached the following image(s):
Lines in Video .PNG (833kb) downloaded 12 time(s).
#2 Posted : Saturday, August 12, 2017 9:47:02 PM(UTC)
Was thanked: 4718 time(s) in 1616 post(s)
Can you confirm the systems specifications? CPU and graphics card?
On low end graphics it is possible for the video from the IO 4K to not copy fast enough causing the artefact you see.
BigApple
#3 Posted : Saturday, August 12, 2017 10:19:13 PM(UTC)
BigApple
Thank you for your reply
MSI Gaming G Series i7 6700 2.6ghz quad core intel HD 530 and NVIDIA GeForce GTX 970M (set as default gfx)
BigApple
#4 Posted : Sunday, August 13, 2017 9:55:56 AM(UTC)
BigApple
So I don't think it is a low end gfx. the lpt is 1 year old and had the best gfx at the time I bough it
#5 Posted : Sunday, August 13, 2017 10:43:06 AM(UTC)
What happens if you run vMix using the Intel Graphics?
This is what the AJA Control Room uses, so I wonder if that will make a difference.
BigApple
#6 Posted : Sunday, August 13, 2017 10:52:21 AM(UTC)
BigApple
thank you , yet I tried that already and to my surprise no difference either ... even with a restart . I also made sure I have the latest NVidia drivers .. still no luck
BigApple
#7 Posted : Monday, December 4, 2017 3:34:57 PM(UTC)
BigApple
Hello admin
now I am on v20 and still the green 4k picture.. any updates
