ELCHAPIN
#1 Posted : Saturday, February 26, 2011 3:47:38 AM(UTC)
ELCHAPIN
HI
Suggestion to add in the future
many use Biblical readings in real time on the video.
as easyworhip and video Bible Free Beam.
we could change the flash or another to enable this feature optional?
Vmix 2011 and is important for stable and fast.
Built with the Bible would be PERFECT
for thousands of churches.
Thanks ...
It's just a good suggestion
Links Biblia's
VIDEO BEAM FREE
Original > http://bibliavideobeam.wordpress.com/ .
EASYWORKSHIP BIBLIA'S
Original site >> http://www.easyworship.com/bible/ .
( google traduccion)
melody
#2 Posted : Saturday, February 26, 2011 6:53:03 AM(UTC)
Rank: Guest
Groups:
(esp) hola elchapin, que bella sugerencia...
Vmix podría presentar cada una de las referencias bíblicas en una plantilla personalizada sin fondo (png), o tal vez sólo una "overlay" de referencias bíblicas ...
de todos modos esto es más una sugerencia de mi voto
saludos,
melody
(en) hello elchapin, what a wonderfull sugestion...
maybe Vmix would can show each of biblical references in custom overlay without background (png), or a dedicated overlay for biblical references...
however, i vote this sugestion
regards,
melody
ELCHAPIN
#3 Posted : Saturday, February 26, 2011 5:04:54 PM(UTC)
ELCHAPIN
It is easy only adds the lbreria of the Bible and go. easyworkship makes videos is very limited.
the letter of the Bible goes well placed in the titles
BIBLE reading.
Martin will know if you can not do in the future
Thanks for the vote Melodia
and visits the forum
#4 Posted : Monday, February 28, 2011 3:42:52 AM(UTC)
Was thanked: 4718 time(s) in 1616 post(s)
I recommend the following:
1. Computer running EasyWorship and the vMix Desktop Capture Server
2. Computer running vMix
EasyWorship is a good product, and instead of spending years developing something similar for vMix, why not use the software that is already out there?
melody
#5 Posted : Monday, February 28, 2011 8:47:55 AM(UTC)
Rank: Guest
Groups:
yes, you are right martin, easyworship is a good software that has been developed over the years and is very good for use on a video projector in the church.
but you also have another side, if a video director wants to use the Bible (the translation does not matter) with the possibility of introducing it (simple thing) in a live production using vmix without having to resort to other software, or capture the desktop, knowing that the easyworship has very specific codec definitions?
regards,
melody
ELCHAPIN
#6 Posted : Tuesday, March 1, 2011 3:53:25 PM(UTC)
ELCHAPIN
if that's logical
But Save the video or burn dvd can not.
I thought it would only add a kind of library and ready.
just add a XAML or POWER POINT
but it seems not possible.
we are not doing less Vmix
a single stop on the computer, only a soft
to avoid overloading the system
we
...... . . . . . . Thanks
