Suggestion to add in the future ! vMix2011
Thanks: 46 times Was thanked: 2 time(s) in 2 post(s)
Rank: Guest
Groups: Guests
(esp) hola elchapin, que bella sugerencia... Vmix podría presentar cada una de las referencias bíblicas en una plantilla personalizada sin fondo (png), o tal vez sólo una "overlay" de referencias bíblicas ...
de todos modos esto es más una sugerencia de mi voto
saludos, melody
(en) hello elchapin, what a wonderfull sugestion... maybe Vmix would can show each of biblical references in custom overlay without background (png), or a dedicated overlay for biblical references...
however, i vote this sugestion
regards, melody
It is easy only adds the lbreria of the Bible and go. easyworkship makes videos is very limited. the letter of the Bible goes well placed in the titles BIBLE reading. Martin will know if you can not do in the future
Thanks for the vote Melodia and visits the forum
Joined: 1/13/2010(UTC) Posts: 5,337  Location: Gold Coast, Australia Was thanked: 4740 time(s) in 1626 post(s)
I recommend the following:
1. Computer running EasyWorship and the vMix Desktop Capture Server 2. Computer running vMix
EasyWorship is a good product, and instead of spending years developing something similar for vMix, why not use the software that is already out there?
Martin vMix
Rank: Guest
Groups: Guests
yes, you are right martin, easyworship is a good software that has been developed over the years and is very good for use on a video projector in the church.
but you also have another side, if a video director wants to use the Bible (the translation does not matter) with the possibility of introducing it (simple thing) in a live production using vmix without having to resort to other software, or capture the desktop, knowing that the easyworship has very specific codec definitions?
regards, melody
Thanks if that's logical But Save the video or burn dvd can not. I thought it would only add a kind of library and ready. just add a XAML or POWER POINT but it seems not possible. we are not doing less Vmix a single stop on the computer, only a soft to avoid overloading the system we ...... . . . . . . Thanks
