3 Pages123>
#1 Posted : Wednesday, August 9, 2017 9:07:36 PM(UTC)
vMix 2X Preview (20.0.0.20 Beta) is here!
Please Note: This is a preview release for those who like to live on the edge! There will still be some bugs, so it is not recommended for production use.
Your feedback is greatly appreciated, please report any bugs or issues in this thread.
Note: New features should not be submitted here, please use the Feature Requests forum instead.
Download Links
http://cdn.vmix.com/download/vmix20preview.exe
New Features and Changes
4K and Pro Editions
* Two additional outputs added with support for vMix Call, Replay and NDI.
* Second Recorder supports independent recording format and can be set to one of 4 Outputs
All Editions
* New Dual Production Clock feature
This can be enabled in Settings -> Options and is placed under the T-Bar where screen space is available.
Other Transition buttons can be turned on or off to make room.
Supports also being added as an input for use in the MultiView Output and also as an NDI output.
* vMix Call: Audio and Video sources can now be changed independently at any time from the right click menu.
Note that CPU usage will increase if each caller has a different video source.
* Improved streaming settings layout.
Each of the 3 destinations now supports independent bitrate and resolution settings.
Hardware Encoder can also be controlled independently for each stream where GeForce cards only support 2 encoders at a time.
* New Channel Matrix added to Input Audio Settings
Each input now has a matrix router with support for up to 8x16 channel configurations
Route different channels from a single input to multiple busses independently and much more!
* Channel Mixer now includes audio meters for each channel
* Reduced CPU when streaming, particular with 4K
* All vMix editions can now connect to a remote vMix Call running HD or higher.
* Added VISCA Over IP PTZ support for newer Sony SRG-360 series cameras.
* Improved performance of Magewell Capture Cards that support 4K60.
* Low Latency option added to vMix Call input. This will disable the buffer that is used to ensure smooth video
during network congestion and should only be used where a high bandwidth connection is assured.
* New TCP API for embedded devices. See Developer Information in the help file for more information.
2X additional features coming later!
For more information on vMix and how it works see the help file:
http://help.vmix.com/20/
thanks 14 users thanked admin for this useful post.
clafarge on 8/9/2017(UTC), SHMD on 8/9/2017(UTC), sinc747 on 8/9/2017(UTC), rowby on 8/9/2017(UTC), RobLambert on 8/9/2017(UTC), ask on 8/9/2017(UTC), mashynewie2 on 8/10/2017(UTC), ON.tv Channels on 8/10/2017(UTC), corporatejames on 8/10/2017(UTC), Amokka on 8/10/2017(UTC), DYosua on 8/10/2017(UTC), rudyengels on 8/12/2017(UTC), jet on 8/18/2017(UTC), PTZOptics on 8/20/2017(UTC)
spino
#2 Posted : Thursday, August 10, 2017 5:09:42 AM(UTC)
spino
Italy
Was thanked: 21 time(s) in 13 post(s)
Download link is down "page not found"
#3 Posted : Thursday, August 10, 2017 5:15:00 AM(UTC)
spino
#4 Posted : Thursday, August 10, 2017 5:28:35 AM(UTC)
spino
Italy
This works: Thank you.
PopisDad
#5 Posted : Thursday, August 10, 2017 5:46:44 AM(UTC)
PopisDad
Maybe it's the OCD in me but now the clock box is an option to display, should not the items above it now be centred rather than left justified? Sorry, but I thought I would have grown out this infliction by now!!
#6 Posted : Thursday, August 10, 2017 6:07:45 AM(UTC)
I believe the gap after the left justified button should be filled by the audio meter when it is active.
ovinas
#7 Posted : Thursday, August 10, 2017 6:09:27 AM(UTC)
ovinas
Nope, because the space to the right is used for the master audio level meter. Throw in some audio and you will see...
StepBackInTime_TV
#8 Posted : Thursday, August 10, 2017 6:43:50 AM(UTC)
StepBackInTime_TV
Was thanked: 17 time(s) in 14 post(s)
Wow Martin! vMix 2X is a dream come true! I am really excited to get testing!
Thank You!
Ittaidv
#9 Posted : Thursday, August 10, 2017 6:50:44 AM(UTC)
Ittaidv
i just saw the 'high input performance mode'. Will test later today what the results are for the x99 wxith the gtx 1080.
dark_ata
#10 Posted : Thursday, August 10, 2017 7:36:45 AM(UTC)
dark_ata
Was thanked: 18 time(s) in 13 post(s)
it not a big problem just a little issue, the clock input and the clock in t-bar have .1 seg of difference
UserPostedImageUserPostedImage
EDIT:
later that i posted i see one of old capture have more difference and more strange
tesn
#11 Posted : Thursday, August 10, 2017 12:49:54 PM(UTC)
tesn
Was thanked: 13 time(s) in 9 post(s)
Great job as always Martin.
I was curious what the production clock looked like. I played with a few settings.
And now it's constantly flashing.
Here's an example:
(I don't know why it recorded in slow motion, but you get the idea)
I wonder if it's a graphics card/performance issue on my not so great pc here.
-Brian
JAIRODJ
#12 Posted : Thursday, August 10, 2017 1:14:32 PM(UTC)
JAIRODJ
Was thanked: 16 time(s) in 12 post(s)
Hello
First congratulate the team of vmix with this new creation that is excellent.
I will give the results of the first tests carried out so far.
1.- At the moment of using a virtual set with NDI source incorporated as screen, NDI audio is freez, stutters. (I used 1 video input, 1 virtual set and 1 NDI input)
2.- After a time of use (approximately 5 minutes) the video of all the previews of all the entries, is cut (freez), only the preview of the windows of 208x156. In preview and master output works well.
3.- There is a flashing of the entire vmix interface from time to time.
tesn
#13 Posted : Thursday, August 10, 2017 1:35:16 PM(UTC)
tesn
Here's an example:
-Brian
And now it's not doing it anymore.
Sorry, that's not too helpful.
sinc747
#14 Posted : Thursday, August 10, 2017 4:37:49 PM(UTC)
sinc747
Production Clock - Possible Bug
Production Clock --> Type = Event, Precision = Minutes --> Minutes & Seconds are displayed
Production Clock --> Type = Event, Precision = Seconds --> Minutes & Seconds & Fractions are displayed
Production Clock --> Type = Event, Precision = Fractions --> Minutes & Seconds & Fractions are displayed
Tested on 2 PC's with same result.
- Tom
#15 Posted : Thursday, August 10, 2017 9:22:25 PM(UTC)
Hi Tom,
For countdown timers, it will show seconds and fractions when there is space available.
So in the final minutes it will show seconds, in the final seconds it will show fractions!
sinc747 on 8/11/2017(UTC), RobLambert on 8/15/2017(UTC)
#16 Posted : Thursday, August 10, 2017 9:24:27 PM(UTC)
For those having flashing and/or delay issues with the clock, could you confirm the graphics card installed?
I suspect the input previews / output can be slightly faster as they use the graphics card directly, while the clock underneath the transitions
is a UI control and updates via Windows.
Ittaidv
#17 Posted : Thursday, August 10, 2017 9:25:09 PM(UTC)
Ittaidv
Tested 'high input performance mode', looks like it works well with + 8 inputs :)
roverradio
#18 Posted : Thursday, August 10, 2017 11:23:51 PM(UTC)
roverradio
Do the extra 2 outputs support output via SDI? It appears there are 4 outputs now, but only 2 available for external/SDI?
Was hoping to have 4 external SDI outputs via Decklink Duo 2. Am I missing something?
element
#19 Posted : Thursday, August 10, 2017 11:43:00 PM(UTC)
element
Ahh, that's what 'High input performance mode' means.. I was reading it as setting your input performance to high and wondering how that would be possible :/
dark_ata
#20 Posted : Friday, August 11, 2017 6:16:08 AM(UTC)
dark_ata
Nvidia GTX 970 WindForce 3X OC 4GB , driver 384.94, windows 10 1607
3 Pages123>
