Murchik
#1 Posted : Friday, August 4, 2017 3:54:32 PM(UTC)
Murchik
Ukraine
Always when switching to another input, the preview is replaced with the input of the exit wizard. If I need to divide the wizard and previews so that only the selected input or image remains always on the preview (especially useful for vMix Call if you use external output 2 in the preview).
There is a possibility (without using overlays which are sometimes not enough) to disable or block (optional for each of the projects) auto-preview window preview ????
dark_ata
#2 Posted : Friday, August 4, 2017 7:55:33 PM(UTC)
dark_ata
Was thanked: 18 time(s) in 13 post(s)
i think that you are searching "CutDirect
Cuts the input directly to Output without changing Preview"
Murchik
#3 Posted : Friday, August 4, 2017 8:00:29 PM(UTC)
Murchik
Ukraine
And what do I need to talk about this ??
ask
#4 Posted : Friday, August 4, 2017 11:32:26 PM(UTC)
ask
Murchik
#5 Posted : Saturday, August 5, 2017 5:57:40 AM(UTC)
Murchik
Ukraine
ask wrote:
Very funny ... I'm not that stupid. Choose the input and switch to another one, the wizard windows and the automatic preview are replaced. And I need to make the window previews static and change only if necessary on command!
dark_ata
#6 Posted : Saturday, August 5, 2017 7:28:47 AM(UTC)
dark_ata
using keyboard or midi shortcut you can do it http://www.vmix.com/help...utFunctionReference.html
#7 Posted : Saturday, August 5, 2017 11:33:21 AM(UTC)
@ Murchik
As dark_ata says, you need to use the "CutDirect" Shortcut and you'll need a different shortcut key for each Input you want to use in Program Output.
Hope that helps some.
Murchik on 8/5/2017(UTC)
Murchik
#8 Posted : Saturday, August 5, 2017 12:32:20 PM(UTC)
Murchik
Ukraine
Thank you. That helped.
