Feature Requests
Is it possible to disable auto-replacement of the preview ???
Joined: 9/13/2016(UTC) Posts: 118   Location: Ukraine Thanks: 6 times Was thanked: 5 time(s) in 4 post(s)
Always when switching to another input, the preview is replaced with the input of the exit wizard. If I need to divide the wizard and previews so that only the selected input or image remains always on the preview (especially useful for vMix Call if you use external output 2 in the preview). There is a possibility (without using overlays which are sometimes not enough) to disable or block (optional for each of the projects) auto-preview window preview ????
Thanks: 11 times Was thanked: 18 time(s) in 13 post(s)
i think that you are searching "CutDirect Cuts the input directly to Output without changing Preview"
dark_ata wrote:i think that you are searching "CutDirect Cuts the input directly to Output without changing Preview" And what do I need to talk about this ??
Very funny ... I'm not that stupid. Choose the input and switch to another one, the wizard windows and the automatic preview are replaced. And I need to make the window previews static and change only if necessary on command!
Joined: 3/7/2012(UTC) Posts: 2,688  Location: Canada Thanks: 33 times Was thanked: 513 time(s) in 481 post(s)
@ Murchik
As dark_ata says, you need to use the "CutDirect" Shortcut and you'll need a different shortcut key for each Input you want to use in Program Output.
Hope that helps some.
Feature Requests
