bluesgeek
#1 Posted : Friday, August 4, 2017 3:28:21 AM(UTC)
bluesgeek
I have four HDMI captures. In creating camera inputs I am selecting audio from camera 1 as Audio Device for all cameras. I can configure 3 cams this way, but trying to save the 4th input fails with: "No combination of intermediate filters could be found to make the connection."
I am able to configure 4 cameras using Line-in as the Audio Device without issue.
Is there a limit to the number of inputs that can use the same HDMI embedded audio?
Thank you.
boris9831
#2 Posted : Friday, August 4, 2017 9:13:31 PM(UTC)
boris9831
r u opening a separate audio input for the audio coming from your HDMI input card?
thanks 1 user thanked boris9831 for this useful post.
bluesgeek on 8/5/2017(UTC)
bluesgeek
#3 Posted : Saturday, August 5, 2017 1:45:15 AM(UTC)
bluesgeek
Thank you, Boris. I'm not sure what you mean.
Here is the workflow.
1) Create new Camera Input from cam 1 and select it as the Audio Device
2) Create a new Camera Input from cam 2 and select Cam1 as the Audio Device
3) Create a new Camera Input from cam 3 and select Cam1 as the Audio Device
4) Create a new Camera Input from cam 4 and select Cam1 as the Audio Device, and receive the not enough filters error.
I tried first creating an Audio Input from Cam1, but that doesn't then appear in the list when selecting Audio Device when creating the Camera Inputs (because it is not a device just an input created from an existing device, Cam1). So the result is the same. I can create 3 Camera Inputs successfully, and error on creating the 4th.
Perhaps you are asking me something else, and I'm not understanding.
Thanks for your help.
boris9831
#4 Posted : Saturday, August 5, 2017 2:37:23 AM(UTC)
boris9831
I guess I don't understand what you want to accomplish. I have a vPrime 4 port HDMI (Magewell chipset?) and it works fine with your scenario. Based on your description you are capturing the same audio for each camera input - why not just add one audio input that uses the audio from cam1? Perhaps the capture card you are using doesn't show the audio inputs separately - see attached.
boris9831 attached the following image(s):
bluesgeek
#5 Posted : Sunday, August 6, 2017 3:21:17 AM(UTC)
bluesgeek
Boris, from the looks of my audio input devices, I don't believe I have that option. Can you tell from this screen shot?
Thanks again.
bluesgeek attached the following image(s):
screenshot audio input.PNG (25kb) downloaded 0 time(s).
bluesgeek
#6 Posted : Monday, September 11, 2017 10:27:24 PM(UTC)
bluesgeek
I think I figured out my problem. I already had some camera inputs configured and stored in a category. I believe the error was the result of trying to have more than one cam input configured the same. Is that possible? All I know is that I deleted the other cam inputs and I was able to configure 4 cams with the same audio device (cam 1). Thanks again for helping. I guess we can file this one under operator error.
