Any Update on this project?
Hello Good work. I have 2 tablets -1x10 ", 1x8" - See photos. Setting graphic properties - Display resolution set to 1024x768. Taskbar, right-click> "Properties"> "Hide Taskbar Automatically", Works without problem so far. Greeting
Thanks: 25 times Was thanked: 8 time(s) in 7 post(s)
Is there also an Android version in the pipeline?
Thanks: 45 times Was thanked: 3 time(s) in 3 post(s)
thecloudmediagroup wrote:al4video wrote:Are you going to add the monitoring of muted audio to the IOS version? If so is there a timeframe?
Thanks Yes, we will be adding that. The interface for the audio meters is a bit different on iOS than Windows. Hopefully it shouldn't take a long time, but my hope is to get the update submitted to Apple in the next couple weeks. Funny thing is, the audio controls don't work at all on my IOS version?
Hey guys, was just running some tests on the controller, and think I found a bug....When I use any transition to switch to a clip, it play well, but when I use the "TAKE" button, it transitions to that input, but if it is a clip, it does not play.....I tried all sorts of things, but can not get the clips to play using the "TAKE" button.....
Joined: 2/27/2013(UTC) Posts: 312   Thanks: 8 times Was thanked: 78 time(s) in 43 post(s)
al4video wrote:thecloudmediagroup wrote:al4video wrote:Are you going to add the monitoring of muted audio to the IOS version? If so is there a timeframe?
Thanks Yes, we will be adding that. The interface for the audio meters is a bit different on iOS than Windows. Hopefully it shouldn't take a long time, but my hope is to get the update submitted to Apple in the next couple weeks. Funny thing is, the audio controls don't work at all on my IOS version? Can you email me at seth@thecloudmediagroup.com so I can help you with your issue?
Joeboe wrote:Hey guys, was just running some tests on the controller, and think I found a bug....When I use any transition to switch to a clip, it play well, but when I use the "TAKE" button, it transitions to that input, but if it is a clip, it does not play.....I tried all sorts of things, but can not get the clips to play using the "TAKE" button..... We were made aware of this today, thank you for the bug report. We'll get that patched up.
JW wrote:Is there also an Android version in the pipeline? I would also be in for an Android version.
Any docs for this software?
Samus4145 wrote:JW wrote:Is there also an Android version in the pipeline? I would also be in for an Android version. That's the plan. Haven't looked into the VB.net to Android port details yet.
lparvin wrote:Any docs for this software? There is a readme.txt file with the program once you download. I can also answer any questions via email at Seth@thecloudmediagroup.com
Any change there is an update coming soon for full screen or higher resolution window?
Joined: 7/31/2017(UTC) Posts: 12   Location: M4R3C Thanks: 3 times Was thanked: 4 time(s) in 4 post(s)
Hello, Last week I bought your app. It seems to be a mistake, or I'm doing something wrong. When loading a video, a stream. Virtual Control Surface is logged out of vMix. (Texts and buttons stop blinking red green) But vMix outputs even though Virtual Control Surface is offline. :( vMix version is 20.0.0.30. , windows 10, But when I create a project where there is no streaming or embedded video file, the application runs perfectly fine. I apologize for my bad English ..: (( Thank you very much for your answer. Petr Mareček mmarejda@seznam.cz
What is happening to this program....No updates as yet?
M4R3C wrote:Hello, Last week I bought your app. It seems to be a mistake, or I'm doing something wrong. When loading a video, a stream. Virtual Control Surface is logged out of vMix. (Texts and buttons stop blinking red green) But vMix outputs even though Virtual Control Surface is offline. :( vMix version is 20.0.0.30. , windows 10, But when I create a project where there is no streaming or embedded video file, the application runs perfectly fine. I apologize for my bad English ..: (( Thank you very much for your answer. Petr Mareček mmarejda@seznam.cz Thanks for the message. Can you send me the text from your vMix XML file. You can locate this by visiting the URL below on the vMix machine. This will help us to troubleshoot the issue. http://127.0.0.1:8088/api/?Function= Please send the XML data in the page to: Seth@TheCloudMediaGroup.com
Has the "TAKE" failure been fixed as yet?....When I use TAKE on the control Surface, the input switches, but if there is a video clip, the video does not play, and has to be started manually....
Joined: 11/25/2017(UTC) Posts: 1 Location: United States
Just curious how the updates are going to be pushed out. Thank you.
travishkelly wrote:Just curious how the updates are going to be pushed out. Thank you. Hey Travis, Updates are downloaded through the FastSpring website. Login to the site and there be download links for new versions:) -Seth
I am having problems logging into the site....I do not have a website, and it is asking for one to proceed to the registration.....is there a direct link to the app.
Joeboe wrote:I am having problems logging into the site....I do not have a website, and it is asking for one to proceed to the registration.....is there a direct link to the app. https://thecloudmediagro...onfastspring.com/accountThis should take you to your account page where you can download the latest version!
