3 Pages<123>
ghayden6
#21 Posted : Saturday, July 1, 2017 2:55:32 PM(UTC)
ghayden6
Any Update on this project?
elvis55
#22 Posted : Sunday, July 2, 2017 4:53:41 AM(UTC)
elvis55
Switzerland
Hello
Good work.
I have 2 tablets -1x10 ", 1x8" -
See photos.
Setting graphic properties - Display resolution set to 1024x768.
Taskbar, right-click> "Properties"> "Hide Taskbar Automatically",
Works without problem so far.
Greeting
JW
#23 Posted : Sunday, July 2, 2017 2:21:20 PM(UTC)
JW
Was thanked: 8 time(s) in 7 post(s)
Is there also an Android version in the pipeline?
al4video
#24 Posted : Wednesday, July 5, 2017 1:30:17 PM(UTC)
al4video
thecloudmediagroup wrote:
al4video wrote:
Are you going to add the monitoring of muted audio to the IOS version? If so is there a timeframe?
Yes, we will be adding that. The interface for the audio meters is a bit different on iOS than Windows. Hopefully it shouldn't take a long time, but my hope is to get the update submitted to Apple in the next couple weeks.
Funny thing is, the audio controls don't work at all on my IOS version?
Joeboe
#25 Posted : Wednesday, July 5, 2017 9:42:02 PM(UTC)
Joeboe
Hey guys, was just running some tests on the controller, and think I found a bug....When I use any transition to switch to a clip, it play well, but when I use the "TAKE" button, it transitions to that input, but if it is a clip, it does not play.....I tried all sorts of things, but can not get the clips to play using the "TAKE" button.....
thecloudmediagroup
#26 Posted : Thursday, July 6, 2017 12:23:13 AM(UTC)
thecloudmediagroup
Rank:: Advanced Member
Was thanked: 78 time(s) in 43 post(s)
Can you email me at seth@thecloudmediagroup.com so I can help you with your issue?
thecloudmediagroup
#27 Posted : Thursday, July 6, 2017 12:24:32 AM(UTC)
thecloudmediagroup
We were made aware of this today, thank you for the bug report. We'll get that patched up.
Samus4145
#28 Posted : Saturday, July 22, 2017 11:55:43 AM(UTC)
Samus4145
I would also be in for an Android version.
lparvin
#29 Posted : Friday, August 4, 2017 12:21:35 AM(UTC)
lparvin
Any docs for this software?
thecloudmediagroup
#30 Posted : Friday, August 4, 2017 3:52:16 AM(UTC)
thecloudmediagroup
That's the plan. Haven't looked into the VB.net to Android port details yet.
thecloudmediagroup
#31 Posted : Friday, August 4, 2017 3:53:18 AM(UTC)
thecloudmediagroup
There is a readme.txt file with the program once you download. I can also answer any questions via email at Seth@thecloudmediagroup.com
Samus4145
#32 Posted : Saturday, September 9, 2017 9:43:35 AM(UTC)
Samus4145
Any change there is an update coming soon for full screen or higher resolution window?
M4R3C
#33 Posted : Saturday, October 21, 2017 8:16:51 PM(UTC)
M4R3C
Czech Republic
Last week I bought your app.
It seems to be a mistake, or I'm doing something wrong.
When loading a video, a stream. Virtual Control Surface is logged out of vMix. (Texts and buttons stop blinking red green)
But vMix outputs even though Virtual Control Surface is offline. :(
vMix version is 20.0.0.30. , windows 10,
But when I create a project where there is no streaming or embedded video file, the application runs perfectly fine.
I apologize for my bad English ..: ((
Thank you very much for your answer.
Petr Mareček
mmarejda@seznam.cz
Joeboe
#34 Posted : Sunday, October 22, 2017 2:45:47 PM(UTC)
Joeboe
What is happening to this program....No updates as yet?
thecloudmediagroup
#35 Posted : Tuesday, October 31, 2017 11:16:24 PM(UTC)
thecloudmediagroup
M4R3C wrote:
Petr Mareček
mmarejda@seznam.cz
Thanks for the message. Can you send me the text from your vMix XML file. You can locate this by visiting the URL below on the vMix machine. This will help us to troubleshoot the issue.
http://127.0.0.1:8088/api/?Function=
Please send the XML data in the page to:
Seth@TheCloudMediaGroup.com
Joeboe
#36 Posted : Wednesday, November 1, 2017 6:26:22 AM(UTC)
Joeboe
Has the "TAKE" failure been fixed as yet?....When I use TAKE on the control Surface, the input switches, but if there is a video clip, the video does not play, and has to be started manually....
travishkelly
#37 Posted : Saturday, November 25, 2017 10:20:08 AM(UTC)
travishkelly
Just curious how the updates are going to be pushed out. Thank you.
thecloudmediagroup
#38 Posted : Saturday, November 25, 2017 7:58:38 PM(UTC)
thecloudmediagroup
Hey Travis,
Updates are downloaded through the FastSpring website. Login to the site and there be download links for new versions:)
-Seth
Joeboe
#39 Posted : Sunday, November 26, 2017 1:31:07 PM(UTC)
Joeboe
I am having problems logging into the site....I do not have a website, and it is asking for one to proceed to the registration.....is there a direct link to the app.
thecloudmediagroup
#40 Posted : Tuesday, November 28, 2017 10:07:10 PM(UTC)
thecloudmediagroup
https://thecloudmediagro...onfastspring.com/account
This should take you to your account page where you can download the latest version!
3 Pages<123>
