castfeeder
#1 Posted : Sunday, July 30, 2017 7:45:00 AM(UTC)
castfeeder
Has anyone had success in using the DuetDisplay app (https://www.duetdisplay.com/) on an iPad with windows 10 pc? I've tried it with Asus laptop (same spec as Sapphire ref system http://www.vmix.com/prod...-systems.aspx#sapphire). Works great with other win10 programs, but Vmix crashes each time. Thought it would be handy to use iPad as a second display.
ovinas
#2 Posted : Sunday, July 30, 2017 12:10:55 PM(UTC)
ovinas
Because the minimum requirement is a DirectX 10 graphics card and you are trying to push the graphics data trough some kind of software simulated graphics card via USB it's like a self protection of vMix... ;-)
thanks 1 user thanked ovinas for this useful post.
castfeeder on 7/30/2017(UTC)
castfeeder
#3 Posted : Sunday, July 30, 2017 2:04:41 PM(UTC)
castfeeder
Thanks for getting back to me Ovinas. I've now been experimenting with Splashtop https://www.splashtop.com/wiredxdisplay and it seems to work just fine with my setup. My main aim is to pop a browser over to the ipad for desktop capture in VM. Touch wood all is ok so far.
ovinas
#4 Posted : Sunday, July 30, 2017 2:17:33 PM(UTC)
ovinas
You should watch render time and dropped frames.
zioncast
#5 Posted: : Wednesday, August 2, 2017 11:19:55 PM(UTC)
zioncast
^^ no problem!
