Duet Display - ipad second monitor
Thanks: 12 times Was thanked: 1 time(s) in 1 post(s)
Has anyone had success in using the DuetDisplay app (https://www.duetdisplay.com/) on an iPad with windows 10 pc? I've tried it with Asus laptop (same spec as Sapphire ref system http://www.vmix.com/prod...-systems.aspx#sapphire). Works great with other win10 programs, but Vmix crashes each time. Thought it would be handy to use iPad as a second display.
Because the minimum requirement is a DirectX 10 graphics card and you are trying to push the graphics data trough some kind of software simulated graphics card via USB it's like a self protection of vMix... ;-)
 1 user thanked ovinas for this useful post.
Thanks for getting back to me Ovinas. I've now been experimenting with Splashtop https://www.splashtop.com/wiredxdisplay and it seems to work just fine with my setup. My main aim is to pop a browser over to the ipad for desktop capture in VM. Touch wood all is ok so far.
You should watch render time and dropped frames.
 ^^ no problem!
