pagu
#1 Posted : Saturday, July 22, 2017 6:30:38 AM(UTC)
pagu
Hello everyone,
i am looking for a get message notification if the stream or line go down,
any suggestion?
Thank you
#2 Posted : Saturday, July 22, 2017 6:38:43 AM(UTC)
Hi Pagu
there are tons of softwares which do this. Best is those which send TEXT message to your phone
You can simply make your own by pinging an internet IP address every 2 or 5 seconds and define an alert when something's wrong
Google is your friend
https://www.google.com/s...et+connection+monitoring
Guillaume
virginia12
#3 Posted : Wednesday, July 26, 2017 4:51:14 AM(UTC)
virginia12
Rank:: Newbie
So much software are available to do this process.You’ve called your internet provider and maybe they helped you and also send TEXT message to your phone.
Thnaks
JW
#4 Posted : Wednesday, July 26, 2017 5:52:58 AM(UTC)
JW
Was thanked: 8 time(s) in 7 post(s)
Be sure that "Block WAN requests" is disabled in the modem/router of the computer you want to monitor.
Otherwise you can't ping it over the internet.
