notification if stream is active
Hello everyone, i am looking for a get message notification if the stream or line go down, any suggestion?
Thank you
Hi Pagu there are tons of softwares which do this. Best is those which send TEXT message to your phone You can simply make your own by pinging an internet IP address every 2 or 5 seconds and define an alert when something's wrong Google is your friend https://www.google.com/s...et+connection+monitoringGuillaume
Hi, So much software are available to do this process.You’ve called your internet provider and maybe they helped you and also send TEXT message to your phone. Thnaks
Thanks: 25 times Was thanked: 8 time(s) in 7 post(s)
Be sure that "Block WAN requests" is disabled in the modem/router of the computer you want to monitor. Otherwise you can't ping it over the internet.
