Feature Requests
Start Streaming on Startup
Joined: 6/16/2015(UTC) Posts: 193   Location: Milton Keynes, UK Thanks: 10 times Was thanked: 53 time(s) in 27 post(s)
Hi
In the same way as we have the ability to start External & Full screen on VMIX startup, would it be possible to have auto start options for Stream and Record?
Keith
 1 user thanked kgoodyer for this useful post.
I would also like this. I am running 24/7 livestream and need it to start in case the PC is restarted.
Yes, task scheduler would work for starting the vMix application but how would it start the livestream?
Thanks: 25 times Was thanked: 8 time(s) in 7 post(s)
You have to wait for sending the stream command until is vMix is started and all the presets are loaded.
My solution is this:
batchfile in startmenu/startup:
ECHO Start vMix start "" "D:\vMix Data\Preset.vmix PING 127.0.0.1 -n 60 > NULL ECHO Start Streaming start "" "D:\vMix Data\start stream.vbs" exit
stream.vbs:
On Error Resume Next
Dim o Set o = CreateObject("MSXML2.XMLHTTP") o.open "GET", "http://127.0.0.1:8088/api/?Function=StartStreaming", False o.send
(this script sends the api without opening a browser)
Btw. I hope vMix will get a 'I am started' trigger which can be assigned to any desired task like streaming, recording, starting a welcome title etc.
 2 users thanked JW for this useful post.
Feature Requests
