kgoodyer
#1 Posted : Wednesday, May 31, 2017 7:50:12 PM(UTC)
kgoodyer
Was thanked: 53 time(s) in 27 post(s)
Hi
In the same way as we have the ability to start External & Full screen on VMIX startup, would it be possible to have auto start options for Stream and Record?
Keith
thanks 1 user thanked kgoodyer for this useful post.
daniep01 on 7/23/2017(UTC)
daniep01
#2 Posted : Sunday, July 23, 2017 10:14:07 AM(UTC)
daniep01
I would also like this. I am running 24/7 livestream and need it to start in case the PC is restarted.
#3 Posted : Sunday, July 23, 2017 10:34:54 AM(UTC)
You have been a member since:: 3/20/2014(UTC)
daniep01
#4 Posted : Sunday, July 23, 2017 11:05:34 AM(UTC)
daniep01
Yes, task scheduler would work for starting the vMix application but how would it start the livestream?
#5 Posted : Sunday, July 23, 2017 11:49:00 AM(UTC)
Using another command to the API
Check here, I have already explained this :
https://forums.vmix.com/...ts&m=36790#post36790
JW
#6 Posted : Tuesday, July 25, 2017 5:57:06 PM(UTC)
JW
Was thanked: 8 time(s) in 7 post(s)
You have to wait for sending the stream command until is vMix is started and all the presets are loaded.
My solution is this:
batchfile in startmenu/startup:
ECHO Start vMix
start "" "D:\vMix Data\Preset.vmix
PING 127.0.0.1 -n 60 > NULL
ECHO Start Streaming
start "" "D:\vMix Data\start stream.vbs"
exit
stream.vbs:
On Error Resume Next
Dim o
Set o = CreateObject("MSXML2.XMLHTTP")
o.open "GET", "http://127.0.0.1:8088/api/?Function=StartStreaming", False
o.send
(this script sends the api without opening a browser)
Btw. I hope vMix will get a 'I am started' trigger which can be assigned to any desired task like streaming, recording, starting a welcome title etc.
thanks 2 users thanked JW for this useful post.
DWAM on 7/25/2017(UTC), G3racingMike on 1/22/2018(UTC)
