3rd Party Software and Development
Adjusting title text or image position via API
Hi, is it possible to adjust position (x, y) of a title text or image using vMix API? I didn't see it mentioned in the user guide, so the answer seems to be no, but before I jump to conclusion, I thought I would ask the forum.
Thanks in advance.
Hi
did you try this :
SetPanX Change current PanX value of Input. 0=centered, -2=100% to left, 2=100% to right Value = Value -2-2
SetPanY Change current PanY value of Input. 0=centered, -2=100% to bottom, 2=100% to top
This works perfectly. Thank you!
