puruzio
#1 Posted : Thursday, July 20, 2017 9:47:29 AM(UTC)
puruzio
Hi, is it possible to adjust position (x, y) of a title text or image using vMix API? I didn't see it mentioned in the user guide, so the answer seems to be no, but before I jump to conclusion, I thought I would ask the forum.
Thanks in advance.
#2 Posted : Thursday, July 20, 2017 11:56:08 AM(UTC)
Hi
did you try this :
SetPanX
Change current PanX value of Input.
0=centered, -2=100% to left, 2=100% to right
Value = Value -2-2
SetPanY
Change current PanY value of Input.
0=centered, -2=100% to bottom, 2=100% to top
puruzio
#3 Posted : Friday, July 21, 2017 9:33:43 AM(UTC)
puruzio
This works perfectly. Thank you!
Guest (4)
