CLaB
#1 Posted : Friday, April 5, 2013 9:31:40 PM(UTC)
CLaB
I am on version 9.0.0.124 I am running 3 or 4 MS LifeCam Studio via USB 3 (works fine) I am trying to record in AVI - DV Video Encoder as the Codec 1280x720 as the size. The output comes out 4:3 -- If I use WMV it records fine, but am looking slightly better quality.
I read here to try using a couple different Codec most recent was Lagaith, but here is when the newbie comes out, I seem to install them (the recommended ones) but I don't know how to get vMix to recognize them. I am sure I am missing a simple concept here.
Any help would be appreciated.
#2 Posted : Sunday, April 7, 2013 2:06:18 PM(UTC)
The DV Encoder only supports standard definition as the resolution.
Try using a different codec. I recommend installing the drivers for the Blackmagic Design Intensity Pro
(even if you don't have any blackmagic hardware) and using the "Decklink MJPEG Compressor" as the codec.
CLaB on 5/31/2013(UTC)
