Joined: 4/2/2013(UTC) Posts: 53  Location: Hungary Thanks: 3 times
I try Vmix 9. By start of streaming is there this error message: Quote:starts DVR for FMLE with the given identifier. Prints all running FMLE instances if identifier is wrong dvrstop fmle_uid Immediately stops DVR for FMLE with the given identifier Prints all running FMLE instances if identifier is wrong or unspecified. /dvrstate fmle_uid Prints DVR status for FMLE with the given identifier. Prints all running FMLE instances if identifier is wrong or unspecified. /help Open FMLE help. Where: auth_string Authentication string. Format depends on authentication module. e.g. username:password. dd:hh:mm dd:days, hh:hours, mm:minutes. Must be max two digits positive integer. fmle_uid FMLE Unique Identifier. fms_url+stream_name if streaming to FMS. Output file path if only encoding to file. External output and Live Encoder it's OK. Thank you.
Joined: 1/13/2010(UTC) Posts: 5,372  Location: Gold Coast, Australia Was thanked: 4799 time(s) in 1647 post(s)
I have the latest version. :(
Test:
with Ustream is OK
but with this format is there a problem rtmp://xxxxxxxxxxxx/xxxxxx stream name: test user: xxxxx pass: xxxxx
The problem is: 64bit
The streaming with 32bit version is OK.
Thanks for letting us know your solution!
