h2video.nl
#1 Posted : Wednesday, June 28, 2017 12:28:32 PM(UTC)
h2video.nl
Hi martin,
first of all a compliment: i noticed that in the multiview settings it is now possible to add a number for the crop settings. A request made some time ago. did not notce the version it was added in but i updated today to v 19.45. and noticed it. very helpfull.
but i also nioticed a bug in the multi view position settings, a small one but a bug anyways:
adjusting the zoom of input 1 is copied to input 2 but can not be adjusted, only the zoom x and zoom y.
i adjusted the zoom of input 1 to 0.80 and that same 0.80 was also in input 2 but not zoomed in. only when i adjusted the x and y zoom of that input i could change the zoom. the master zoom did not respond...
stefan
#2 Posted : Wednesday, June 28, 2017 2:04:33 PM(UTC)
@ h2video.nl
Is your issue related to this previously mentioned observation: ?
https://forums.vmix.com/...ts&m=36385#post36385
h2video.nl
#3 Posted : Wednesday, June 28, 2017 2:38:32 PM(UTC)
h2video.nl
hi Ice,
yes exactly like that.
so it seems to be a global issue. maybe Martin could have a look. nothing serious, but for unexperienced users very confusing.
stefan
#4 Posted : Wednesday, June 28, 2017 6:27:34 PM(UTC)
Was thanked: 4711 time(s) in 1615 post(s)
Hi Stefan,
Can you provide step by step instructions to replicate? In the last thread I was unable to duplicate the problem
suspecting that some strange issue related to slow graphics card updates on the system may have caused it.
h2video.nl
#5 Posted : Thursday, June 29, 2017 8:32:01 AM(UTC)
h2video.nl
hi Martin,
the problem is exactly like ice pointed out.
this is what i did:
1 opened two inputs: one camera and one desktop ndi capture 16:9
2 opened a color input and opened a multi view. selected nr 1 side by side
3 adjusted input one - the camera, set the adjustement to reset and then brought back to zoom 0.80 and pan to right
4 opened input two - the ndi desktop capture and noticed the 0.80 zoom alteady there. adjustment does not work.
just adjusted the x and y settings and noticed that only when i go unde 0.80 the number is changed.
the 0.80 seems like. harmles remnant of the previous view.
I can do some more tests but have to go to germany now for recording tomorrow.
stefan
