rickvoskamp
#1 Posted : Tuesday, June 27, 2017 4:36:24 PM(UTC)
rickvoskamp
I want to change the text color of a title (XAML) using the API.
Is it possible already? I have not found a solution yet.
#2 Posted : Tuesday, June 27, 2017 4:56:59 PM(UTC)
no but there are a few workaround options with adapted titles by sending values to hidden textfields that are binded with your visible textfields
There have been a few examples posted in the forum
#3 Posted : Tuesday, June 27, 2017 5:03:58 PM(UTC)
a few link to get started
Here
and
Here
rickvoskamp
#4 Posted : Wednesday, June 28, 2017 1:09:08 PM(UTC)
rickvoskamp
Here
and
Here
Thanks, i used this solution!
Next 'problem':
I want tot put a default # in front, so i can update the color with the API using a HEX-code? Who can help me?
{Binding Text, ElementName=COLOR_BLOCK_1}
Update: I found a solution:
Code:
http://192.168.1.26:8088/api/?function=SetText&input=1&SelectedName=homeBackgroundColor&Value=%23000000
Use: %23 to get a #.
#5 Posted : Friday, February 23, 2018 9:13:07 AM(UTC)
SetTextColor is now in the API
User is suspended until 7/1/2029 2:52:17 AM(UTC) najafysmm
#6 Posted : Monday, December 11, 2023 10:27:36 PM(UTC)
najafysmm
United Arab Emirates
Hi
I saw your post about ticker text color change vmix web api
and tries much more urls
http://127.0.0.1:4473/api/Function=SetColor&Input=55eda683-f779-40c2-bcff-bcb272040131&Value=FF4040&SelectedName=Ticker1.Text
http://127.0.0.1:4473/api/Function=SetColor&Input=55eda683-f779-40c2-bcff-bcb272040131&Value=#FF4040&SelectedName=Ticker1.Text
http://127.0.0.1:4473/api/?Function=SetColor&Input=55eda683-f779-40c2-bcff-bcb272040131&Value=#00FF4040&SelectedName=Ticker1.Text
http://127.0.0.1:4473/api/?Function=SetColor&Input=55eda683-f779-40c2-bcff-bcb272040131&Value=%23FF4040&SelectedName=Ticker1.Text
but nothing Happens !
tnx 4 ur help
raugert
#7 Posted : Tuesday, December 12, 2023 1:09:19 AM(UTC)
raugert
Canada
Originally Posted by: najafysmm Go to Quoted Post
Hi
tnx 4 ur help
Try using "SetTextColor" instead of "SetColor"
thanks 1 user thanked raugert for this useful post.
najafysmm on 12/31/2023(UTC)
#8 Posted : Sunday, December 31, 2023 9:11:06 PM(UTC)
najafysmm
tnx alot
i solved it
but there is a new problem here
it cant be to change the color
and a flash not occur in title
as you know it happens when manually change the text color of subtitles
and also will be done when automatically done with web api
#9 Posted: : Sunday, December 31, 2023 10:16:50 PM(UTC)
tnx alot
i solved it
What flash (a sudden brief burst of bright light.)?
#10 Posted : Monday, January 1, 2024 3:42:57 PM(UTC)
najafysmm
Hi Mr Doggy
yes
take a look at this video
Flashing Subtitle When Color Changes
i dont know how to share it with you
Rec 0029c.avi (3,527kb) downloaded 12 time(s).
as you see in this video
when i try to change the ticker color
it flashes and bring back to previous words before spacing red circle
what is the solution for this ?
normal text is white
and red circle is separator
#11 Posted : Monday, January 1, 2024 6:46:20 PM(UTC)
Hi Mr Doggy
yes
This is not a "flash: but a restart of the ticker animation due to change in color, font or content which is normal behaviour for a GT ticker.
A ticker is a single "animated" Textblock container you can not change during this action be it font or color.
While one can "add" content/data to the title field instead of "replace" as ticker type to get mutiple added data to one line , changing color or font will reset the animation with is current content .
Solution is t make sure one does not change color or font while content is visible during the passing of the content
