Feature Requests
Change text color with API
I want to change the text color of a title (XAML) using the API.
Is it possible already? I have not found a solution yet.
no but there are a few workaround options with adapted titles by sending values to hidden textfields that are binded with your visible textfields
There have been a few examples posted in the forum
Thanks, i used this solution! Next 'problem': I want tot put a default # in front, so i can update the color with the API using a HEX-code? Who can help me? Quote:{Binding Text, ElementName=COLOR_BLOCK_1}
Update: I found a solution: Code:http://192.168.1.26:8088/api/?function=SetText&input=1&SelectedName=homeBackgroundColor&Value=%23000000
Use: %23 to get a #.
SetTextColor is now in the API
Joined: 11/28/2023(UTC) Posts: 9  Location: Abudabi Thanks: 1 times
Hi I saw your post about ticker text color change vmix web api and tries much more urls http://127.0.0.1:4473/api/Function=SetColor&Input=55eda683-f779-40c2-bcff-bcb272040131&Value=FF4040&SelectedName=Ticker1.Text http://127.0.0.1:4473/api/Function=SetColor&Input=55eda683-f779-40c2-bcff-bcb272040131&Value=#FF4040&SelectedName=Ticker1.Text http://127.0.0.1:4473/api/?Function=SetColor&Input=55eda683-f779-40c2-bcff-bcb272040131&Value=#00FF4040&SelectedName=Ticker1.Text http://127.0.0.1:4473/api/?Function=SetColor&Input=55eda683-f779-40c2-bcff-bcb272040131&Value=%23FF4040&SelectedName=Ticker1.Text but nothing Happens ! tnx 4 ur help
Joined: 8/5/2017(UTC) Posts: 583  Location: Manitoba Thanks: 121 times Was thanked: 323 time(s) in 184 post(s)
Originally Posted by: najafysmm  Hi I saw your post about ticker text color change vmix web api and tries much more urls http://127.0.0.1:4473/api/Function=SetColor&Input=55eda683-f779-40c2-bcff-bcb272040131&Value=FF4040&SelectedName=Ticker1.Text http://127.0.0.1:4473/api/Function=SetColor&Input=55eda683-f779-40c2-bcff-bcb272040131&Value=#FF4040&SelectedName=Ticker1.Text http://127.0.0.1:4473/api/?Function=SetColor&Input=55eda683-f779-40c2-bcff-bcb272040131&Value=#00FF4040&SelectedName=Ticker1.Text http://127.0.0.1:4473/api/?Function=SetColor&Input=55eda683-f779-40c2-bcff-bcb272040131&Value=%23FF4040&SelectedName=Ticker1.Text but nothing Happens ! tnx 4 ur help Try using "SetTextColor" instead of "SetColor"
 1 user thanked raugert for this useful post.
tnx alot i solved it but there is a new problem here it cant be to change the color and a flash not occur in title as you know it happens when manually change the text color of subtitles and also will be done when automatically done with web api
Originally Posted by: najafysmm  tnx alot i solved it but there is a new problem here it cant be to change the color and a flash not occur in title What flash (a sudden brief burst of bright light.)?
Hi Mr Doggy yes take a look at this video Flashing Subtitle When Color Changesi dont know how to share it with you  Rec 0029c.avi (3,527kb) downloaded 12 time(s).as you see in this video when i try to change the ticker color it flashes and bring back to previous words before spacing red circle what is the solution for this ? normal text is white and red circle is separator
Originally Posted by: najafysmm  Hi Mr Doggy yes take a look at this video Flashing Subtitle When Color Changesi dont know how to share it with you  Rec 0029c.avi (3,527kb) downloaded 12 time(s).as you see in this video when i try to change the ticker color it flashes and bring back to previous words before spacing red circle what is the solution for this ? normal text is white and red circle is separator This is not a "flash: but a restart of the ticker animation due to change in color, font or content which is normal behaviour for a GT ticker. A ticker is a single "animated" Textblock container you can not change during this action be it font or color. While one can "add" content/data to the title field instead of "replace" as ticker type to get mutiple added data to one line , changing color or font will reset the animation with is current content . Solution is t make sure one does not change color or font while content is visible during the passing of the content
Feature Requests
