Under Settings -> Recording -> Filename Format
Where is documentation on how to modify or code this? I want the format to simply output 'yyyy-MM-dd ARC' without anything in front. So, an example from today would be: '2016-09-17 ARC.mp4'
Currently, my format setting is '{0} {1:yyyy-MM-dd} ARC' This results in 'capture 2016-09-17 ARC.mp4' I just want to eliminate the 'capture ' from the recorded file name, but I keep getting errors when I try to remove that first part of the format.
BTW, I am using vMix 16.0.0.115 x64 Thanks for the help.
I don't know about v16 but with v17 I can use 'ARC.mp4' and produce a file called 'ARC 17 September 2016 - hh-mm-ss PM' where h=hours, m=minutes and s=seconds of the recorded time of day. Will that suffice?
- Tom
In the recording setup window, in the file name field, you type the name you want the file to have: xxxxx.mp4. That name that is put is the one that assigns the file with the parameter {0}, that is in the configuration window> recording> filename format.
I hope this is useful for you.
