arlinsandbulte
#1 Posted : Sunday, September 18, 2016 1:02:50 PM(UTC)
arlinsandbulte
Under Settings -> Recording -> Filename Format
Where is documentation on how to modify or code this?
I want the format to simply output 'yyyy-MM-dd ARC' without anything in front.
So, an example from today would be: '2016-09-17 ARC.mp4'
Currently, my format setting is '{0} {1:yyyy-MM-dd} ARC'
This results in 'capture 2016-09-17 ARC.mp4'
I just want to eliminate the 'capture ' from the recorded file name, but I keep getting errors when I try to remove that first part of the format.
BTW, I am using vMix 16.0.0.115 x64
Thanks for the help.
sinc747
#2 Posted : Sunday, September 18, 2016 11:19:26 PM(UTC)
sinc747
Was thanked: 204 time(s) in 170 post(s)
I don't know about v16 but with v17 I can use 'ARC.mp4' and produce a file called 'ARC 17 September 2016 - hh-mm-ss PM' where h=hours, m=minutes and s=seconds of the recorded time of day. Will that suffice?
- Tom
Dragoniant
#3 Posted : Tuesday, June 27, 2017 2:04:19 PM(UTC)
Dragoniant
In the recording setup window, in the file name field, you type the name you want the file to have: xxxxx.mp4. That name that is put is the one that assigns the file with the parameter {0}, that is in the configuration window> recording> filename format.
I hope this is useful for you.
Similar Topics
Recoding - Filename Format (General Discussion)
by ccolewilliam 8/17/2021 12:50:42 AM(UTC)
Recording "Filename Format" syntax? (General Discussion)
by FBCAV 6/12/2017 5:28:25 PM(UTC)
