Assuming this is possible, allowing cropping that is outside the x-y axis would be helpful. We often shoot score clocks from an angle and this would be helpful to get a clean crop.
Joined: 4/14/2013(UTC) Posts: 264 ![Man Man](/Themes/yafpro/male.gif) Location: Australia Thanks: 35 times Was thanked: 38 time(s) in 36 post(s)
It's possible to make a mask shape in Photoshop, and use this to mask an input in the colour key, key fill selector.
![thanks](/Themes/yafpro/heart_small.png) 1 user thanked Peter B for this useful post.
Thats a good idea.
I would still rather have the ability to do it on the fly, but that is a definite work around.
You could grab a still on the fly from vMix and use that in PS as a guide to make a mask. This also makes soft edge masking possible. Using an animated mask will create custom wipes.
