kjones9999
#1 Posted : Sunday, June 25, 2017 9:47:32 PM(UTC)
kjones9999
Assuming this is possible, allowing cropping that is outside the x-y axis would be helpful. We often shoot score clocks from an angle and this would be helpful to get a clean crop.
Peter B
#2 Posted : Sunday, June 25, 2017 10:20:08 PM(UTC)
Peter B
It's possible to make a mask shape in Photoshop, and use this to mask an input
in the colour key, key fill selector.
thanks 1 user thanked Peter B for this useful post.
kjones9999 on 6/25/2017(UTC)
kjones9999
#3 Posted : Sunday, June 25, 2017 10:29:00 PM(UTC)
kjones9999
Thats a good idea.
I would still rather have the ability to do it on the fly, but that is a definite work around.
Peter B
#4 Posted : Sunday, June 25, 2017 10:45:57 PM(UTC)
Peter B
You could grab a still on the fly from vMix and use that in PS as a guide to make a mask. This also makes soft edge masking possible. Using an animated mask will create custom wipes.
