Joined: 3/25/2013(UTC) Posts: 3 Location: Netherlands
In the new Streaming Settings I cannot set the Audio format from MP3 to AAC (I have to use the MainConcept AAC Encoder).
Tried changing setting in file "C:\Users\<USERNAME>\AppData\Roaming\Adobe\Flash Media Live Encoder 3.2\Startup.xml" but doesn't work.
New vMix Streaming creates a xml like "C:\Users\<USERNAME>\AppData\Local\Temp\tmp4D54.tmp.xml" for starting FMLE in the background with fixed "MP3" audio format:
<encode> <video> <format>H.264</format> ... </video> <audio> <format>MP3</format> <datarate>96</datarate> </audio> </encode>
The logfile "C:\Users\<USERNAME>\AppData\Local\Temp\tmp4D54.tmp.xml.log" also states using MP3:
Sun Mar 24 2013 16:44:21 : Video Settings :- Device : vMix Video Format : H.264 ...
Audio Settings :- Device : vMix Audio Format : Mp3 Stereo Sample Rate : 44100 Hz Bit rate : 96 Kbps Volume : 100 %
For now I use FMLE again. Hope this can be fixed in a future release for instance with an extra option in Streaming Settings.
Tnx for creating and maintaining vMix!
Rob
Joined: 1/13/2010(UTC) Posts: 5,372  Location: Gold Coast, Australia Was thanked: 4799 time(s) in 1647 post(s)
In the vMix installation directory you can edit the profile.xml file in the streaming folder.
Martin vMix
