Saving Profiles in Streaming Settings
Each week I have to go in and set up all of my streams under Streaming Settings. I tried to set up a new profile and save the settings but they disappear every time I restart the program. I've tried this multiple times and I click "save and close" each time.
If I set up a profile and save my streaming settings should they return each time I open the program? What am I doing wrong?
Joined: 4/23/2017(UTC) Posts: 1,488  Location: Germany Thanks: 3 times Was thanked: 197 time(s) in 177 post(s)
There is a profile drop down. Click add and create a new profile. You can select it in a later session again.
@mavik but he said he clicked "save and close" and it did not work, so what is the purpose of creating a new profile?
@ jthomson955 & rgrimes
The “Save and Close” option in Stream Settings only saves that profile in your current “running” project, you then need to save it as a vMix Preset if you want to save it permanently (for the next time you run VMix).
