"Stammelement ist nicht vorhanden" - root xml element not available - Instant Replay probl
Thanks: 39 times Was thanked: 39 time(s) in 35 post(s)
my machine crashed today on me and after reloading the Vmix preset, the instant replay input couldnt be opened anymore.
It says "Stammelement ist nicht vorhanden", which means something like "root xml element not available" in german.
Is there a way to retrieve the xml root element somehow?
Can I get my events back? The machine crashed after the production ended, so all marked events of the entire football game would be on it.
I hope there is a way to get them back.
Regards, Patrick
Joined: 1/13/2010(UTC) Posts: 5,372  Location: Gold Coast, Australia Was thanked: 4799 time(s) in 1647 post(s)
Yes, in the replay folder there are two files, replay.xml and replay.xml.backup if replay.xml is corrupt you can replace it with the backup, though usually vMix does this automatically.
Martin vMix
unfortunately it still doesn't work. Is there anything else to do?
Email us a copy of both files so we can see if they can be recovered.
Email is sent
Update: Okay, I just saw that the file is empty...so I guess there is no way to get the data back, right?
