netaccs
#1 Posted : Saturday, June 3, 2017 2:58:36 AM(UTC)
netaccs
Hello everyone !
As I understand vMix doesn't support command line, but it offers alternative - web controller.
Could that make it possible ?
For example:
Start the vMix program, load some saved preset, cut window 2 in to program, insert image in windows 4 using some transition,
start facebook, youtube stream, with settings like - channel selection, privacy, bitrate, command for stopping broadcast, recording and etc.
Thanks in advance !
Digitalson
#2 Posted : Saturday, June 3, 2017 11:28:49 PM(UTC)
Digitalson
Groups:
Well I am making a iPad app that can control about everything in vmix....so yes
netaccs
#3 Posted : Thursday, June 8, 2017 3:45:14 AM(UTC)
netaccs
Is it ready, any way to test it ?
And anyway can that be done using command line, shell or something else ?
pm
#4 Posted : Thursday, June 8, 2017 7:47:10 AM(UTC)
pm
Was thanked: 33 time(s) in 28 post(s)
vMix is manageable thru command line. You can use any script language like Powershell, VBScript, Perl, etc. There are a lot of examples here in the forum.
Using scripts you can connect to the vMix API and control what ever you want. API Reference: http://www.vmix.com/help19/DeveloperAPI.html
Patrick
