vMix command line/Web Controller
Hello everyone ! As I understand vMix doesn't support command line, but it offers alternative - web controller.
Could that make it possible ? For example: Start the vMix program, load some saved preset, cut window 2 in to program, insert image in windows 4 using some transition, start facebook, youtube stream, with settings like - channel selection, privacy, bitrate, command for stopping broadcast, recording and etc.
Thanks in advance !
Groups: Guests
Well I am making a iPad app that can control about everything in vmix....so yes
Is it ready, any way to test it ?
And anyway can that be done using command line, shell or something else ?
Thanks: 12 times Was thanked: 33 time(s) in 28 post(s)
vMix is manageable thru command line. You can use any script language like Powershell, VBScript, Perl, etc. There are a lot of examples here in the forum. Using scripts you can connect to the vMix API and control what ever you want. API Reference: http://www.vmix.com/help19/DeveloperAPI.htmlRegards, Patrick
