a4k
#1 Posted : Thursday, November 3, 2016 6:31:11 AM(UTC)
a4k
Hello, we have the camcorder JVC GY-HM200 capable of emitting by the following protocols streaming RTMP, MPEG2-TS / UDP, MPEG2-TS / TCP, RTSP / RTP, ZIXI.
You could vmix (version 17 pro) receive stream directly from the camera?
Thank.
ask
#2 Posted : Thursday, November 3, 2016 6:52:12 AM(UTC)
ask
Have a look at the Help files here: http://www.vmix.com/help17/index.htm?Stream.html
a4k on 11/3/2016(UTC)
progresstv
#3 Posted : Thursday, November 3, 2016 5:29:58 PM(UTC)
progresstv
Thank.
yes it works.
You have to set the camera in UDP and on VMIX set trasport stream over UDP
remeber to set your firewall
henri55
#4 Posted : Monday, November 7, 2016 10:35:55 AM(UTC)
henri55
http://jvcwebseminar.3d-...g_and_Optics_GWE_v2a.pdf
These guides look exactly like with my JVC GY-HM650 so it should work. With HM650 UDP and RTSP works over wifi.
henri55
#5 Posted : Friday, November 11, 2016 12:22:25 PM(UTC)
henri55
Have to add little warning about using set transport stream over UDP. I think it's bug with vMIX, but if you some reason lost connection to the camera (vMIX says connection error), vMIX can't recover the connection without restarting the program. vMIX thinks the UDP port is still in use and can't receive more than one stream from one port.
rinaldo
#6 Posted : Tuesday, November 29, 2016 6:02:49 PM(UTC)
rinaldo
That's right! Be warn with the audio when streaming in transport stream UDP to vMix... Sometimes work sometimes not :-(
dnavarrojr
#7 Posted : Wednesday, November 30, 2016 4:44:49 PM(UTC)
dnavarrojr
Has this bug been reported? I am planning to use my JVC cameras to do live streaming of Basketball in February and I want as few hiccups as possible.
dnavarrojr
#8 Posted : Thursday, December 1, 2016 3:57:50 PM(UTC)
dnavarrojr
JVC Camera Settings
Record Set
->System: HD
->Resolution: 1920x1080
->Frame Rate: 30p
->Bit Rate: 30M
Network Settings->Live Streaming Set
->Type: MPEG2-TS/UDP
->Destination Address: <ip of my laptop>
->Destination Port: 6504
->PCR Jitter: Normal
vMix Settings
Stream Type: Transport Stream over UDP
Port: 6504
Buffer: 1000
Make sure you turn Streaming ON in the camera menu.
Ittaidv
#9 Posted : Thursday, December 1, 2016 4:04:36 PM(UTC)
Ittaidv
Anyone who can tell how much latency is added for encoding this mpeg 2 stream? I can imagine ndi is faster, no?
dnavarrojr
#10 Posted : Friday, December 2, 2016 3:37:29 PM(UTC)
dnavarrojr
I have seen no delay between the camera and vMix.
I borrowed a JVC GY-HM300 last night and using it and my HM200 I did a two camera Facebook Live broadcast with no issues. Worked great.
Followyourblissmedia
#11 Posted : Friday, June 2, 2017 12:28:43 AM(UTC)
Hey everyone. Trying to get my JVC HM200 ingested into vMix wirelessly in any way possible. I've tried following the instructions above for RTSP transport UDP, with no luck. I'm testing anything I can think of and welcome any feedback. Thanks!
vMix trial 19.0.0.47
Windows 10
ASUS 2.5ghz
500 SSD
2TB HD
2 GB VRAM
Camera settings:
HD
1080 60i
bitrate 5.0M
UDP
address: ipaddress
port: 6504
vMix settings:
Stream
Transport stream over UDP
Port 6504
1000 ms buffer
master frame: 1080 60i
Speegs
#12 Posted : Friday, June 2, 2017 3:38:42 AM(UTC)
Speegs
If it works in VLC maybe you can use the new Vmix VLC Plugin.
It's BRAND NEW and described here:
#13 Posted : Friday, June 2, 2017 5:13:30 PM(UTC)
Thanks. I'll try VLC tonight. But I'm interested in feedback from users like @dnavarrojr who have had success streaming directly from the camera to vmix via the RTSP/UDP protocol. If anyone can help me dial this in I would really appreciate it. I'm brand new to vmix so I'm still learning the program. I was able to ingest into Wirecast no problem but prefer to use vmix as it has more overall features I want. And since multiple users are reporting success in vmix with this protocol, I'm hoping to set mine up the same way.
Forgot to mention in my previous post. I'm on a home LAN 30mbs down and 5mbs up.
And I of course have the streaming on, however it seems to only show live in the camera in red instead of yellow.
#14 Posted : Sunday, June 4, 2017 2:55:29 PM(UTC)
No luck with VLC. Can anyone help? I'm dedicating this entire weekend to getting this going and really need some help. Thanks in advance.
UPDATE: I'm now able to see the feed in VLC using RTSP. But when I select VLC stream in Vmix and enter the same URL I'm using in VLC, the feed in Vmix is just a solid black blank screen.
Camera:
RTSP
Password: 0000
VLC
rtsp://<cameraipaddress>:554/stream
stream looks great, about a second latency
When trying in vMix
Stream type: VLC
URL- rtsp://192.168.0.5:554/stream
blank black screen no video or audio
#15 Posted : Sunday, June 4, 2017 3:49:16 PM(UTC)
@ Followyourblissmedia
Did you download and install the plug-in "vlcforvmix.exe" as per the instructions in the YouTube link that Speegs provided above?
#16 Posted : Sunday, June 4, 2017 4:09:24 PM(UTC)
Hello IceStream. Thanks so much for the reply. Yes i downloaded the plugin and see the VLC option in Stream window in vMix, and I'm able to see the stream in VLC using rtsp://192.168.0.5:554/stream, but when I use the same url in vmix, the input is a black screen, no video or audio.
Stream Type: VLC
ask
#17 Posted : Monday, June 5, 2017 5:07:40 AM(UTC)
ask
Are you on the latest version of vMix 19.0.0.50? and have you downloaded and installed the VLC plugin?
#18 Posted : Monday, June 5, 2017 11:50:29 AM(UTC)
Yes I am on the latest version 19.0.0.50 and have successfully installed the VLC plugin.
Followyourblissmedia attached the following image(s):
VLC Codec Info.PNG (90kb) downloaded 9 time(s).
vMix stream display.PNG (123kb) downloaded 9 time(s).
#19 Posted : Monday, June 5, 2017 4:58:31 PM(UTC)
I FIGURED IT OUT! I found an article with some info that helped. I changed the URL to include the username and password and it works! Thanks for everyone's help!
rtsp://user:pass@cameraipaddress:554/stream
