mark
#1 Posted : 8 years ago
mark
Figured this is the right forum for this question.
Need to be able to send a Vmix output to another Vmix but the connection speed is slow so need to only send a RTMP stream.
Anyone out there manged to import an acceptable RTMP stream back into another Vmix?
Only method I am a ware of so far is to use a hardware encoder and send that instead.
Any pointers out there would be appreciated.
Mark
#2 Posted : 8 years ago
Was thanked: 794 time(s) in 589 post(s)
Hi
you cannot stream RTMP from vMix to vMix: you need a RTMP server in between.
but you could use vMixCall for direct stream between 2 vMix hosts. It supports up to 1080p 4Mbits.
Guillaume
thanks 2 users thanked DWAM for this useful post.
mark on 5/30/2017(UTC), stigaard on 5/30/2017(UTC)
kjones9999
#3 Posted : 8 years ago
kjones9999
Hi Mark. I have done this using Mistserver. I couldnt believe how easy it was.
I documented the steps here:
https://goo.gl/pyOKLq
thanks 1 user thanked kjones9999 for this useful post.
guztavo on 6/25/2017(UTC)
Gyapi
#4 Posted : 8 years ago
Gyapi
An interesting solution.
NDI is flawless!
The customer requests +1 streaming + voice on the spot.
How to fix when we do not have more video distributors!
Vmix - NDI, find a tool and work flawlessly! :)
