NDI
Vmix to Vmix using not NDI
Thanks: 5 times Was thanked: 2 time(s) in 2 post(s)
Figured this is the right forum for this question. Need to be able to send a Vmix output to another Vmix but the connection speed is slow so need to only send a RTMP stream. Anyone out there manged to import an acceptable RTMP stream back into another Vmix? Only method I am a ware of so far is to use a hardware encoder and send that instead.
Any pointers out there would be appreciated.
Mark
Joined: 3/20/2014(UTC) Posts: 2,720   Location: Bordeaux, France Thanks: 243 times Was thanked: 796 time(s) in 590 post(s)
Hi
you cannot stream RTMP from vMix to vMix: you need a RTMP server in between.
but you could use vMixCall for direct stream between 2 vMix hosts. It supports up to 1080p 4Mbits.
Guillaume
 2 users thanked DWAM for this useful post.
Hi Mark. I have done this using Mistserver. I couldnt believe how easy it was. I documented the steps here: https://goo.gl/pyOKLq
 1 user thanked kjones9999 for this useful post.
Thanks: 12 times Was thanked: 1 time(s) in 1 post(s)
An interesting solution. NDI is flawless! The customer requests +1 streaming + voice on the spot. How to fix when we do not have more video distributors! Vmix - NDI, find a tool and work flawlessly! :)
NDI
